![]() | Home > Maintenance & Mods (L322) > How to bleed new fuel filter |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
You shouldn't need to bleed the fuel filter. May require a few extra cranks initially but should fire up after that. This assumes all is well on the fuel delivery system further back down the line! .
As above, just crank the engine 3 times with out letting it start so as to fill the filter, then go for it.
Rob Member Since: 17 Jan 2015 Location: south Posts: 6 ![]() ![]() ![]() |
Thanks for that I really appreciate it |
viper Member Since: 11 Apr 2015 Location: manchester Posts: 271 ![]() ![]() ![]() |
is this the same for a tdv8, no bleed required ? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Just stick the ignition on for 20 secs at a time 2 or 3 times to help the pumps refill the system then crank till it starts |
thankyou |
Pilgrimmick Member Since: 11 Mar 2016 Location: West Coast Posts: 64 ![]() ![]() ![]() |
What does the dead end pipe do then? Got enemies? Good, you have stood up for something in your life. Never regret growing old, it is a privilege denied to many. |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
AKAIK its a turbo breather.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6761 ![]() ![]() ![]() |
If it still won't start, pull off the plastic engine cover and look for a pipe that has what looks like a tyre valve, remove the cap and push it down as you crank the engine.
