Home > Maintenance & Mods (L322) > How to bleed new fuel filter
Rob
Ireland 2005 Range Rover HSE Td6 Java Black
hi I went to change fuel filter on my l322 and noticed a dead end pipe along side main fuel filter with a small clear plastic filter on the end as if it is to suck in some fuel...can you help please
Post #305830 17th Jan 2015 3:06pm
You shouldn't need to bleed the fuel filter. May require a few extra cranks initially but should fire up after that. This assumes all is well on the fuel delivery system further back down the line! .
Post #305842 17th Jan 2015 3:29pm
As above, just crank the engine 3 times with out letting it start so as to fill the filter, then go for it.
Might run a little lumpy for a few seconds but will soon pick up.
The dead end pipe has nothing to do with the fuel filter. Thumbs Up
Post #305861 17th Jan 2015 4:10pm
Rob
Thanks for that I really appreciate it
Post #305874 17th Jan 2015 4:31pm
viper
is this the same for a tdv8, no bleed required ?
Post #324366 25th Apr 2015 4:40pm
Just stick the ignition on for 20 secs at a time 2 or 3 times to help the pumps refill the system then crank till it starts Thumbs Up Leave it to run for 10 mins so it clears any more air from the system... Thumbs Up
Post #324381 25th Apr 2015 5:45pm
viper
thankyou
Post #324384 25th Apr 2015 6:03pm
Post #324416 25th Apr 2015 7:59pm
Pilgrimmick
Scotland 2004 Range Rover Vogue Td6 Java Black
What does the dead end pipe do then? Got enemies? Good, you have stood up for something in your life.
Never regret growing old, it is a privilege denied to many.
Post #380413 2nd Apr 2016 10:31am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
AKAIK its a turbo breather.
Post #380498 3rd Apr 2016 5:43am
If it still won't start, pull off the plastic engine cover and look for a pipe that has what looks like a tyre valve, remove the cap and push it down as you crank the engine.
Edited to say, this is on the TDV8, the TD6 may not have this. Got - 2017 SDV8 Autobiography in Loire Blue
Post #380504 3rd Apr 2016 8:53am
