![]() | Home > Technical (L322) > 03 L322 battery drain |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
Have you checked what voltage your getting when engine off, then on tick over and under load?
Coconut Member Since: 12 Feb 2016 Location: Watford Posts: 36 ![]() ![]() ![]() |
Yes that was tested and the alternator was ok.
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 135 ![]() ![]() ![]() |
I've just bought an 03 L322 as well.
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Sat nav can spit the dummy and the CD will be continuously ejected only to be re inserted by the over and over again. |
Thank you
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8368 ![]() ![]() ![]() |
Do a search on Final Stage Resistor FSR.. most common cause of depleted batteries....
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
Do the headlight wipers work - if they don't park properly or one of the motors doesn't run that will also cause a battery drain when the ignition is switched off as the power feed stays open. Current Fleet:-
calletso Member Since: 27 Jan 2016 Location: North Yorkshire Posts: 12 ![]() ![]() |
My battery drain was caused by water ingress to the DSP amp - worth pulling the conectors out and have a look.
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 37 ![]() ![]() ![]() |
The number 1 cause for my battery drain on my 03 TD6 was the aftermarket Nokia HF set, which was draining 120ma on its own (unused).
tony motor Member Since: 10 Feb 2016 Location: derbyshire Posts: 2 ![]() |
The Amp in the back can cause battery drain, it sometime will not go to sleep, there is a company on EBay that you take your amp out send it to them and they put all new software in and Guarantee it for life. |
rattly Member Since: 15 Oct 2016 Location: Cotswolds Posts: 42 ![]() ![]() ![]() |
Have similar on my 03 TD6, headlamp wipers work and park, sat nav is switching off, it does have the Nokia Hf kit still in it, are these fused separately, ie how can I disconnect it?? |
