Home > Technical (L322) > 03 L322 battery drain
Coconut
United Kingdom 2003 Range Rover HSE Td6 Barolo Black
Hi
Have recently inherited my fathers 03 L322.
He had owned the car for the previous 10 years, and when left for more than about five days the battery would run flat.
Over the last few weeks I have experienced a flat battery after an hour and a half run.
On the back of that I have purchaced a new battery and this seems to slowly drain down as well.
An AA patrolman mentioned that there was a fault on these early models but it should have been resolved when main dealer serviced.
Can anyone shed some light on this issue?
Thanks
Post #376406 8th Mar 2016 7:59pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Have you checked what voltage your getting when engine off, then on tick over and under load?
should see 12.6 when the engine is off, and 14.5 when charging.
Post #376417 8th Mar 2016 8:34pm
Coconut
Yes that was tested and the alternator was ok.
Thanks
Post #376420 8th Mar 2016 8:42pm
wood78987
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
I've just bought an 03 L322 as well.
Previous owner had disconnected the sat nav unit in the boot as it was draining the battery. Give that a shot.
Post #376438 8th Mar 2016 9:37pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Sat nav can spit the dummy and the CD will be continuously ejected only to be re inserted by the over and over again.
Post #376445 8th Mar 2016 10:39pm
Coconut
Thank you
I will give that a try
Post #376489 9th Mar 2016 10:23am
Do a search on Final Stage Resistor FSR.. most common cause of depleted batteries....
The gps dvd's also forget to turn off, open the passenger side boot cubby, turn off and lock the car and after 16minutes the light on the front of it should go out, view it through the window as if you unlock or open the car it will switch back on....
Good luck... Thumbs Up Thumbs Up Pete
Post #376520 9th Mar 2016 12:02pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Do the headlight wipers work - if they don't park properly or one of the motors doesn't run that will also cause a battery drain when the ignition is switched off as the power feed stays open. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #376524 9th Mar 2016 12:25pm
calletso
2002 Range Rover Vogue 4.4 V8 Giverny Green
My battery drain was caused by water ingress to the DSP amp - worth pulling the conectors out and have a look.
http://www.fullfatrr.com/forum/topic35923.html
Thanks
Chris
Post #376534 9th Mar 2016 2:19pm
sass
Finland 2016 Range Rover Vogue TDV6 Kaikoura Stone
The number 1 cause for my battery drain on my 03 TD6 was the aftermarket Nokia HF set, which was draining 120ma on its own (unused).
The number 2 cause is the immobilizer unit which is draining 30-40ma more than it should. The authorized dealer said they could try to re-flash it, but if it fails a new unit would cost 1200 euros.
Now the drainage in sleep mode is 60ma.
Post #376535 9th Mar 2016 2:25pm
tony motor
The Amp in the back can cause battery drain, it sometime will not go to sleep, there is a company on EBay that you take your amp out send it to them and they put all new software in and Guarantee it for life.
Post #376592 9th Mar 2016 8:56pm
rattly
Have similar on my 03 TD6, headlamp wipers work and park, sat nav is switching off, it does have the Nokia Hf kit still in it, are these fused separately, ie how can I disconnect it??
Post #409546 16th Oct 2016 5:44pm
