Home > Technical (L322) > 03 L322 battery drain |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 |
Have you checked what voltage your getting when engine off, then on tick over and under load?
8th Mar 2016 7:34pm |
Coconut Member Since: 12 Feb 2016 Location: Watford Posts: 36 |
Yes that was tested and the alternator was ok.
8th Mar 2016 7:42pm |
wood78987 Member Since: 03 Mar 2016 Location: South Wales Posts: 134 |
I've just bought an 03 L322 as well.
8th Mar 2016 8:37pm |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
Sat nav can spit the dummy and the CD will be continuously ejected only to be re inserted by the over and over again. |
8th Mar 2016 9:39pm |
Thank you
9th Mar 2016 9:23am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8318 |
Do a search on Final Stage Resistor FSR.. most common cause of depleted batteries....
9th Mar 2016 11:02am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 |
Do the headlight wipers work - if they don't park properly or one of the motors doesn't run that will also cause a battery drain when the ignition is switched off as the power feed stays open. Current Fleet:-
9th Mar 2016 11:25am |
calletso Member Since: 27 Jan 2016 Location: North Yorkshire Posts: 12 |
My battery drain was caused by water ingress to the DSP amp - worth pulling the conectors out and have a look.
9th Mar 2016 1:19pm |
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 34 |
The number 1 cause for my battery drain on my 03 TD6 was the aftermarket Nokia HF set, which was draining 120ma on its own (unused).
9th Mar 2016 1:25pm |
tony motor Member Since: 10 Feb 2016 Location: derbyshire Posts: 2 |
The Amp in the back can cause battery drain, it sometime will not go to sleep, there is a company on EBay that you take your amp out send it to them and they put all new software in and Guarantee it for life. |
9th Mar 2016 7:56pm |
rattly Member Since: 15 Oct 2016 Location: Cotswolds Posts: 42 |
Have similar on my 03 TD6, headlamp wipers work and park, sat nav is switching off, it does have the Nokia Hf kit still in it, are these fused separately, ie how can I disconnect it?? |
16th Oct 2016 4:44pm |
