Home > Technical (L322) > jumping whilst selecting gear
alistairh
Took the ff out for the first time in 2 months today...noticed whenever I select drive or reverse the car slightly jumps .when its on the move its fine..? I'm planning on getting a gearbox service shortly as well....never had a rangie and my only comparison is my merc which is smooth upon selection?
Post #409496 16th Oct 2016 12:22pm
Certainly jumps if it's cold as the revs are raised, what is yours ticking over at when warm, should be 700rpm with aircon on...
They will never match a merc for smoothness... too many joints between the gearbox and the wheels...
If it's real bad all the time then it could be propshaft joints x 4, axle slop x 2, or driveshaft joints x 8..... Thumbs Up Pete
Post #409531 16th Oct 2016 4:34pm
alistairh
It does sit at 700 with aircon on Off Topic I've noticed it dips to about 500rpm then straight back to 700 once engines warmed up? This happens a few times then eventually stops !...Thanks for the input..will get the joints checked out whilst its at my mates garage getting a big service next week..first proper drive of the ff today,zero stereo on ..the v8 sounds amazing! Best car I've owned to date...
Post #409537 16th Oct 2016 5:03pm
