Home > Technical (L322) > EML not illuminating |
Zigzagsky Member Since: 18 Oct 2015 Location: Sandhurst Posts: 39 |
Quick update on this.
21st Feb 2016 6:08pm |
Ok so I've had the dash apart and removed the instrument cluster. The connectors to the wiring loom seem fine and I've sprayed contact cleaner on the plugs but it still does not illuminate.
27th Feb 2016 6:41pm |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Hi
27th Feb 2016 8:31pm |
Thanks for checking. The handbook says it should come on but now I'm beginning to wonder... 2005 Range Rover L322 TD6
27th Feb 2016 11:36pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
My guess and only a guess I am afraid is that the handbook has misinformation my handbook has a couple of things in not correct and also the fact that it illuminates on test implies that the circuitry is ok so there must be no signal
28th Feb 2016 7:35am |
Yes, beginning to look like it may be normal behaviour for this particular variant. 2005 Range Rover L322 TD6
28th Feb 2016 2:27pm |
Swiftman Member Since: 23 Jan 2013 Location: Midlothian Posts: 128 |
Hi I have a 2006 model & have never seen the mil light on since I got car 3 years ago. does not come on with bulb check . |
29th Feb 2016 2:29am |
So normal behaviour
29th Feb 2016 9:47am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Yep. Can also confirm, contrary to the hand book, mine doesn't light up either.
29th Feb 2016 3:40pm |
