Home > Technical (L322) > Error Codes
Realist
Wales
Error Codes
Hi all.
I've recently purchased a 2007 SE FFRR V8 and plugged a code reader into it and received the following codes, can someone tell me if these are something that I should have a look at or they are not that serious.
Instrument Pack
B1A82 - External trip switch circuit
U2016 - Control Module Main Software
Parking Brake Control
U0101 - Lost communication with transmission control module
Front Lighting control module
U0102 - Lost communication with transfer case control module
All terrain control module
Drivers seat control
B1153 - drivers seat cushion
Running board control module
C1003 Power running board - right stow
Transfer case control module
P0562 - System voltage low
U0073 - Control module communication bus off
U0155 - Lost communication with instrument cluster control module
U0126 - Lost communication with steering angle sensor module.
Vehicle immobilizer control module
B1B01 - Key Transponder
Rear entertainment control module
B1D50 - DVD unit
Traffic message channel module
B1A56 - DSM Drivers seat slide control relay failure. Other antenna circuit
Light Check Module
Fault in communication with vehicle ECU
Anyone with ideas?
Post #372941 18th Feb 2016 12:48pm
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
I'm just guessing here but
P0562 - System voltage low ---- battery issue?
Batteries throw up a load of errors and if the power is low would it not struggle to communicate with various control units? 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #372948 18th Feb 2016 1:21pm
clear all the codes and then check in a weeks time..you'll probably find most are historical.. ... - .- -.
Post #372951 18th Feb 2016 1:34pm
Realist
Wales
I have cleared all the codes and checked again 7 days later and that's what showed up.
I'll do it again and see what it throws back at me in a few days time.
Thanks.
Post #372954 18th Feb 2016 1:44pm
ah ok, you could search here on the forum or google...pretty sure theres a code site linked in the wiki... ... - .- -.
Post #372955 18th Feb 2016 1:48pm
Realist
Wales
Code site linked?
U mean their is a site that lists what each code means cos Ive search and cant find any.
Post #372957 18th Feb 2016 2:56pm
from the wiki,
http://www.obd-codes.com/ ... - .- -.
Post #372959 18th Feb 2016 2:59pm
Realist
Wales
Just found a site that lists the codes quite well and it says for the following:
P0562 - Charging System Voltage Low
Possible causes
- Low battery charge
- Battery defective
- Loose or missing alternator drive belt
- Faulty alternator
- Open or short system voltage circuit
Notes:
Start by recharging or replacing the battery.
When is the code detected?
The Engine Control Module (ECM) has detected that the electrical system voltage level is out of range.
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Slow engine start
- Low battery power
P0562 Description
The battery supplies electricity to the Engine Control Module (ECM) even when the ignition switch is OFF. This electricity allows the ECM to store data such as Detected Trouble Code (DTC) history, freeze frame data, fuel trim values and other data. If the battery voltage falls below a minimum level, the ECM will conclude that there is a fault in the power supply circuit. The next time the engine starts, the ECM will turn on the Malfunction Indicator Light (MIL) and a DTC will be set.
Post #372961 18th Feb 2016 3:03pm
Realist
Wales
For code U2016 - Signal Link Short to Ground (Non SCP) / From NGV Module
It says: Possible symptoms
No lights showing up and the last service was done 7000 miles ago by the previous keeper!
Post #372962 18th Feb 2016 3:06pm
philbathurst
United Kingdom 2016 Range Rover Vogue SE TDV6 Montalcino Red
here is link for some of your fault codes
https://goo.gl/dawfci
its not comprehensive but you may find more on the site
I searched for Ford fault codes various other LR's this one is still the best
Post #372964 18th Feb 2016 3:12pm
put the voltage monitor on the nav screen on on the hidden menu, see what the alternator is putting out. It could be that your alternator is on the way out. It should be 13.5-14.5v when running. There is nothing that can't be fixed with a hammer😜😜
Post #372970 18th Feb 2016 4:19pm
dingg1
alternator or battery issue I'd guess at
Post #373015 18th Feb 2016 8:23pm
Mikey
Are you having any specific issues?
Post #373017 18th Feb 2016 8:36pm
Realist
Wales
Naa no issues at all apart from when I first had the car the dash screen said something about engine management but that cleared after a good run and someone said it could of been where the car was sat on the dealers.
How do I get to the hidden menus?
Post #373024 18th Feb 2016 10:09pm
hidden menu info in the wiki,
http://www.fullfatrr.com/gallery/albums/us...gnosis.pdf ... - .- -.
Post #373048 19th Feb 2016 7:06am
