Home > Technical (L322) > Error Codes |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
Hi all.
18th Feb 2016 12:48pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35330 |
clear all the codes and then check in a weeks time..you'll probably find most are historical.. ... - .- -.
18th Feb 2016 1:34pm |
I have cleared all the codes and checked again 7 days later and that's what showed up.
18th Feb 2016 1:44pm |
ah ok, you could search here on the forum or google...pretty sure theres a code site linked in the wiki... ... - .- -.
18th Feb 2016 1:48pm |
Code site linked?
18th Feb 2016 2:56pm |
from the wiki,
18th Feb 2016 2:59pm |
Just found a site that lists the codes quite well and it says for the following:
18th Feb 2016 3:03pm |
For code U2016 - Signal Link Short to Ground (Non SCP) / From NGV Module
18th Feb 2016 3:06pm |
philbathurst Member Since: 28 Apr 2013 Location: Iver Posts: 137 |
here is link for some of your fault codes
18th Feb 2016 3:12pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8523 |
put the voltage monitor on the nav screen on on the hidden menu, see what the alternator is putting out. It could be that your alternator is on the way out. It should be 13.5-14.5v when running. There is nothing that can't be fixed with a hammer😜😜
18th Feb 2016 4:19pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1345 |
alternator or battery issue I'd guess at |
18th Feb 2016 8:23pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1764 |
Are you having any specific issues? |
18th Feb 2016 8:36pm |
Naa no issues at all apart from when I first had the car the dash screen said something about engine management but that cleared after a good run and someone said it could of been where the car was sat on the dealers.
18th Feb 2016 10:09pm |
hidden menu info in the wiki,
19th Feb 2016 7:06am |
