![]() | Home > Technical (L322) > Error Codes |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1815 ![]() ![]() |
Ignore them then ![]() |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 ![]() ![]() |
Thank you your a star |
Done just this tonight and the screen said 12.0v idle and when running its showing 13.5v.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
What Craig said, the alternator is doing something, however I would also now check with a volt meter across the battery terminals at idle and confirm the 12v. If it is only 12v then the alternator is dying. It should put out 13.5v minimum at idle, rising to 14.5 when it is charging after starting.
Tested with my multimeter tonight and at standing between the + and - it reads 12.0v and starting up, running lights, heaters everything to get the alternator to kick in and it reads 13.5v max.
Now who lives in South Wales and is handy at changing Alternators? |
Found a mechanic that can supply and fit the alternator for £435.00 is that cheap or expensive? |
lighthouse Member Since: 22 Feb 2016 Location: Great Notley Posts: 513 ![]() ![]() ![]() |
sounds on the expensive side, what motor you got? |
FFRR TDV8. |
no idea where it is on the diesel so can't advise on the effort required would have thought part would be around £200 mark |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Very much doubt you would get a decent alternator for one of them for £200...
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
you can get a decent deal for these alternators Pete |
Blimey they have come down a bit in price... nearly as cheap as the earlier ones now.... |
Yeh that's about the prices I've been finding. |
