Home > Technical (L322) > TD6 slight vibration at 1500 rpm
Mac1971
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
I am noticing very slight vibration / resonance at about 1500 rpm . Seems to be in all gears and when car stationary and in park . I have read about torque converter and injector issues . No fluctuation in tacho when driving and all gear changes seem to be fine . Any info would be welcome please , thanks in advance
Post #372591 16th Feb 2016 7:39am
miggit
Well the good news is that it isn't the gearbox Thumbs Up
It could be an injector fault, but they normally manifest themselves from tick over and disappear at 2000 rpm +. You could try some injector cleaner.
It could be the torque converter has somehow gone off balance, but is also unlikely.
The only thing that I can think of is possibly an engine mount, or an extreme case of paranoia (which is a side effect of owning a ffrr). You need either another TD6 ffrr owner to sit in yours or a good indy, or you need to try another car....... just in case it's nothing, or something... at least you wont be having nightmares about it Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #372599 16th Feb 2016 9:07am
What size wheels do you have on it ? 2008 MY Supercharged
Post #372601 16th Feb 2016 9:38am
miggit
Embarassed forgot that one........... still running 18's on mine so I've never experienced big wheel rattle Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #372604 16th Feb 2016 10:06am
Don't think the size of wheels will effect it when it's stood still, but I've never had big wheels and it is an FF so anything is possible I suppose... Pete
Post #372608 16th Feb 2016 10:33am
It's something to think about though , for those affected I think it was worse when stationary . 2008 MY Supercharged
Post #372613 16th Feb 2016 11:15am
miggit
Whistle was that affected or afflicted Laughing
Bearing in mind that we are talking Tractor here, I still recon that engine mount / injector fault are the most likely, actually I recon that Roverphobia (expecting something to go wrong) is the most probable cause...
And Mac1971, please don't think that's a slur on you, we all go down the road expecting something to fall off, and then panic when it doesn't Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #372623 16th Feb 2016 1:28pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Rolling with laughter Rolling with laughter Rolling with laughter
I call it bongitus Laughing
have experienced vibration stationery and maneuvering slowly ie to get on off drive, this is mostly prominent in access mode.
the only other problem I have heard about is the flex plate on the g/box, but don't know that much about them, something like their is a crack in it or it's breaking up. Other than that as above. Thumbs Up
Post #372633 16th Feb 2016 1:58pm
Embarassed effected affected smafected .
There is also one active engine mount to counteract the more " tractor " tendencies of the TD6 . 2008 MY Supercharged
Post #372637 16th Feb 2016 2:14pm
miggit
Which is what I was thinking about...... vacuum operated I believe...... sucks the engine on to the mount at revs.
Cracked flex plate is a possibility, they are flimsy things even in a Yank...... and the ffrr's only has 3 bolts holding the torque converter to the plate, so there's more scope for failure........ I'll let you know at the weekend as I'm changing the converter on mine Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #372639 16th Feb 2016 2:28pm
gregdav
@Mac1971.
as has been stated, try the most easiest first, although I have read the vacuum pipes that feed the engine mounts can be tricky to access.
But if you have a split or hole in one it may give you the symptoms you're experiencing.
@ miggit, good luck the weekend with your tc change out. Thumbs Up
Post #372641 16th Feb 2016 3:09pm
Mac1971
Thanks all , " roverphobia " is definitely a symptom . It's running on 22's , didn't know the wheel size could be a problem until I came across it on the forum but it's something I'm thinking about Changing due to having to worry about any kerbs or pot holes larger than an inch. I will have a good look at the weekend , you can feel it through the floor pan rather than hear it . I have switched to bp ultimate diesel about a week ago so that' is having a phsychological effect ( is it running smoother / quieter ) , cheers
Post #372655 16th Feb 2016 4:44pm
miggit
Shocked 22's have you no shame... tractors are supposed to have big bouncy tyres Wink Might be worth putting a shout out to see if someone has a set that you can try, you can't be the only ffrr owner in your area Thumbs Up
Roverphobia is a nasty condition, but it can sometimes be eased by chanting....... " I don't give a Censored , I don't give a Censored ", if that doesn't work you could try Banging Head Banging Head Banging Head Yesterday I couldn't spell Engineer... Today I are one!
Post #372723 16th Feb 2016 11:49pm
22' Wheels Shocked , I don't think we need look any further , If you like the wheels enough you might be able to put up with a permanent low speed resonance . 2008 MY Supercharged
Post #372730 17th Feb 2016 12:41am
isn't the rule of thumb that TD6's don't like anything over 19", which is why they were never fitted with anything larger out of the factory? Because they caused this type of vibration.
I would try an borrow some standard 18" or 19" wheels and see if it goes away. There is nothing that can't be fixed with a hammer😜😜
Post #372788 17th Feb 2016 3:21pm
