Home > Technical (L322) > TD6 slight vibration at 1500 rpm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Well the good news is that it isn't the gearbox
16th Feb 2016 9:07am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
What size wheels do you have on it ? 2008 MY Supercharged
16th Feb 2016 9:38am |
forgot that one........... still running 18's on mine so I've never experienced big wheel rattle Yesterday I couldn't spell Engineer... Today I are one!
16th Feb 2016 10:06am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8186 |
Don't think the size of wheels will effect it when it's stood still, but I've never had big wheels and it is an FF so anything is possible I suppose... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Parchment over Navy Interior. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand, Jet Interior. Sold 2002 L322 Vogue 4.4 V8 Epson Green, Ivory over Aspen Interior (Fatty Offroader) Sold -Click for Project Fatty off roader- |
16th Feb 2016 10:33am |
It's something to think about though , for those affected I think it was worse when stationary . 2008 MY Supercharged
16th Feb 2016 11:15am |
was that affected or afflicted
16th Feb 2016 1:28pm |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
16th Feb 2016 1:58pm |
effected affected smafected .
16th Feb 2016 2:14pm |
Which is what I was thinking about...... vacuum operated I believe...... sucks the engine on to the mount at revs.
16th Feb 2016 2:28pm |
@Mac1971.
16th Feb 2016 3:09pm |
Mac1971 Member Since: 17 Jan 2016 Location: Hartlepool Posts: 30 |
Thanks all , " roverphobia " is definitely a symptom . It's running on 22's , didn't know the wheel size could be a problem until I came across it on the forum but it's something I'm thinking about Changing due to having to worry about any kerbs or pot holes larger than an inch. I will have a good look at the weekend , you can feel it through the floor pan rather than hear it . I have switched to bp ultimate diesel about a week ago so that' is having a phsychological effect ( is it running smoother / quieter ) , cheers |
16th Feb 2016 4:44pm |
22's have you no shame... tractors are supposed to have big bouncy tyres Might be worth putting a shout out to see if someone has a set that you can try, you can't be the only ffrr owner in your area
16th Feb 2016 11:49pm |
22' Wheels , I don't think we need look any further , If you like the wheels enough you might be able to put up with a permanent low speed resonance . 2008 MY Supercharged
17th Feb 2016 12:41am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
isn't the rule of thumb that TD6's don't like anything over 19", which is why they were never fitted with anything larger out of the factory? Because they caused this type of vibration.
17th Feb 2016 3:21pm |
