Home > Maintenance & Mods (L322) > -3 this morning........ |
rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185 |
Plan of action tomorrow is to buy myself an amp tester and check before starting.
20th Jan 2016 12:15am |
betonklinker Member Since: 19 Nov 2015 Location: Amsterdam / Netherlands Posts: 68 |
I hope to have found the battery drain .. the sat nav . remains continuously on. Have the cables disconnected from the radio module, amp. and sat. nav.-unit (the radio did not work so and has yet to be replaced by a aftermarket)
21st Jan 2016 3:48pm |
My sat-nav is already removed.
21st Jan 2016 3:58pm |
I'm happy.... the problem for the drain by my car was the Nav. Sat.
22nd Jan 2016 2:44pm |
its funny because to replace the Sat Nav is over £100 when you could be a Tom Tom for less which is better and has live traffic reports. |
22nd Jan 2016 2:49pm |
Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128 |
Hi Seb.
22nd Jan 2016 10:17pm |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 539 |
just a thought on random battery drain. I had this on mine ('03 L322 4.4V8). Changed the heater hedgehog resistor to fix a malfunctioning aircon (kept going to full fan whenever the sun shone through the windscreen), fixed both. No more random battery drain, and heater fan works as it should. |
23rd Jan 2016 9:19am |
777.......
23rd Jan 2016 10:45am |
rvbush.......
23rd Jan 2016 10:46am |
Oops, missed that you'd already refered to this, sorry about that! |
23rd Jan 2016 12:16pm |
no problems. I called it that many a time too. |
23rd Jan 2016 1:07pm |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 |
Although trying to get down to battery drain I never succeeded in finding it (pulled all the fuses, renewed FSR, installed new alternator). Finally did the second battery fit out last year and in December I put in a VSR (Voltage sensitive relay) between the batteries. This VSR is an intelligent one: 1) ignition off = isolated batteries, 2) charging above 13.6V = batteries connected, 3) below 12.8V = isolated batteries, 3) when car is started and starter battery voltage drops below 11.6V the second battery will also kick in, and 4) my own invented extra: when remote action of FBH = second battery kicks in for as long the FBH is active.
23rd Jan 2016 9:08pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
^ Can you tell me the capacity (AH) of the second battery you installed? |
23rd Jan 2016 9:12pm |
Can you share some pictures please?
23rd Jan 2016 9:13pm |
