Home > Maintenance & Mods (L322) > -3 this morning........
Page 2 of 3 <123>
betonklinker
Netherlands 2004 Range Rover Vogue Td6 Bonatti Grey
Interresting topic.. I use Google translate, Sorry for my bad English...
Full Vogue Td6, new Gearbox, 22 inch Stormers, HSE, Cream leather
Post #368062 20th Jan 2016 12:29am
rangeseb
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Plan of action tomorrow is to buy myself an amp tester and check before starting.
If the battery is 12.4 volts or higher and fails to start then it's the starter motor.
If the battery read 11 volts or less then the battery drain is still the problem
I will update in due course
Post #368063 20th Jan 2016 1:15am
betonklinker
I hope to have found the battery drain .. the sat nav . remains continuously on. Have the cables disconnected from the radio module, amp. and sat. nav.-unit (the radio did not work so and has yet to be replaced by a aftermarket)
The Alternator is in good condition say's the garage today. So I watching tomorrow what's happens to Start, battery is full at the moment and I hope tomorrow also Wink (next option to do FSR) I use Google translate, Sorry for my bad English...
Post #368299 21st Jan 2016 4:48pm
rangeseb
My sat-nav is already removed.
I'm now moving onto the FSR, after that the starter motor.
to be fair it started today at 6am at -2 and all day yesterday.
I need to wait for my battery volt checker to come from amazon then i can test the battery.
Good Luck
Post #368305 21st Jan 2016 4:58pm
betonklinker
I'm happy.... the problem for the drain by my car was the Nav. Sat. Bow down
This morning a powerfull battery and start whit out problems and no HDC symbol short on the dash. I use Google translate, Sorry for my bad English...
Post #368423 22nd Jan 2016 3:44pm
rangeseb
its funny because to replace the Sat Nav is over £100 when you could be a Tom Tom for less which is better and has live traffic reports.
Post #368424 22nd Jan 2016 3:49pm
Duracell777
Hi Seb.
New toy not up to the job of starting car from (properly) flat or not tried it:?:
Not read any previous posts about this, so may be way late to the party but are there any lights being left on such as glove box for example Question I say this as my uncle had a new car in the 80's with constant battery drain and it turned out to be the boot light not going off. I understand yours seems to be intermittent but just a thought Thumbs Up
Hope you sort it soon.
Andy
Post #368489 22nd Jan 2016 11:17pm
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
just a thought on random battery drain. I had this on mine ('03 L322 4.4V8). Changed the heater hedgehog resistor to fix a malfunctioning aircon (kept going to full fan whenever the sun shone through the windscreen), fixed both. No more random battery drain, and heater fan works as it should.
Post #368519 23rd Jan 2016 10:19am
rangeseb
777.......
The pack has been used 3 times so far on the fatty. Battery not fully dead but not enough to start engine.
Connected up and off she went!
It also got a run out on my Samsung S5 and Ipad.
Post #368527 23rd Jan 2016 11:45am
rangeseb
rvbush.......
the hedgehog is the FSR (Final stage Resistor) it will be changed but just waiting for payday as there are a few bits i need for the FF.
Post #368528 23rd Jan 2016 11:46am
rvbush
Oops, missed that you'd already refered to this, sorry about that!
Post #368540 23rd Jan 2016 1:16pm
rangeseb
no problems. I called it that many a time too.
Post #368547 23rd Jan 2016 2:07pm
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Although trying to get down to battery drain I never succeeded in finding it (pulled all the fuses, renewed FSR, installed new alternator). Finally did the second battery fit out last year and in December I put in a VSR (Voltage sensitive relay) between the batteries. This VSR is an intelligent one: 1) ignition off = isolated batteries, 2) charging above 13.6V = batteries connected, 3) below 12.8V = isolated batteries, 3) when car is started and starter battery voltage drops below 11.6V the second battery will also kick in, and 4) my own invented extra: when remote action of FBH = second battery kicks in for as long the FBH is active.
And now for the results: been on skiing holiday last week in Italy. Every morning before skiing and every evening after skiing the FBH was used for ½ hour. When starting in the morning many days of -11, -13 and even -15. Started every time powerful, and never had a HDC warning Mr. Green No more worries for me with the battery.
I'm really happy I did install the second battery with VSR. Thanks to the inspiration I found on this forum! Bow down Thumbs Up
Post #368588 23rd Jan 2016 10:08pm
^ Can you tell me the capacity (AH) of the second battery you installed?
Post #368589 23rd Jan 2016 10:12pm
rangeseb
Can you share some pictures please?
Thanks
Post #368591 23rd Jan 2016 10:13pm
Page 2 of 3 <123>
