Home > General > What Did You Do In Your Full Fat Today |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
went to london last night to see the luminia show and honestly my xmas tree had better lights than what was shown..
17th Jan 2016 9:57am |
Mactech Member Since: 27 Jun 2015 Location: Biddulph Posts: 126 |
Ventured out in sub zero temps for the first time in this car. The car lived in Aberdeen for it's first couple of years so I'm sure it has seen lower than the -5 deg I saw in the local valley yesterday. I used the heated steering wheel for the first time. Toastie!
17th Jan 2016 11:10am |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
Mactech, keep the air con on all year prevents condensation.
17th Jan 2016 8:18pm |
betonklinker Member Since: 19 Nov 2015 Location: Amsterdam / Netherlands Posts: 68 |
Made my door that did not open or locked before start .... and after that I drive a round. I use Google translate, Sorry for my bad English...
17th Jan 2016 10:33pm |
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 |
got 2 new pirellis on to replace the horrible continentals (that even with 5mm left on them were sliding about the place in the wet) now sitting on good tyres all round. |
18th Jan 2016 8:11pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
Developed the famous knocking noise from some where underneath over the last couple of weeks. Got it on a ramp today and decided that the drop links looked suspect. So two links changed and noise now seems to have gone. Only £28 for the two from a local motor factors.... amazing how a simple noise can drive you mad !! |
19th Jan 2016 10:20pm |
Jimmy C Member Since: 05 Feb 2015 Location: midlands Posts: 115 |
Noticed a bit of oil on the drive, so discovered a local land rover indy 4 miles away that i didn't know exsisted
20th Jan 2016 8:01am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Replaced my CV and ball joint gaiters ,CV ones had to come from the UK but weren't to bad , about $60, but the Ball joint gaiters were $6 that's the first time I have bought a part here when I have not had to sit down for a while
21st Jan 2016 10:39am |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Removed the full sized spare wheel which took some effort, Checked for leaks, started to sweep a little dust/debris that had collected in the wheel well then decided to leave it as a Heath Robinson moisture indicator.
21st Jan 2016 10:47am |
I have disconnect the nav./sat./radio/amp.-module's and hope that the drain is over I use Google translate, Sorry for my bad English...
22nd Jan 2016 12:02am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8622 |
collected it from a service. seems to be running ok :thumbs:
22nd Jan 2016 4:38pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2655 |
Sitting on motorway at 70, restricted performance , hard shoulder, switch off , all ok. Ink it's a split hose. Got home and now the reverse camera kaput! |
25th Jan 2016 7:20pm |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Replaced the old wipers for Aeros ( so far only tried at a standstill on the drive but defo less clunk than the originals ) ......Gummi pfleged all the door seals and treat it to a new set of rubber mats all round, |
26th Jan 2016 12:53am |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Had a break in the weather this am so decided to fit a set of genuine mud flaps recently purchased. What a ball ache of a job to fit the front ones, 3 hours rolling round on the drive is not good for a man of my years. Not the sort of job that can be abandoned once started though. It seems the easiest way to locate some of the fasteners is to have an extra joint inserted in each finger as it is really difficult. Fronts are done now so just need a fine day to do the rears that look a little easier. Wish someone had mentioned it before though cos I wouldn't have bothered. 😅😅😅 Agueroooooooooo. 93-20
27th Jan 2016 6:38pm |
