Home > General > What Did You Do In Your Full Fat Today |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Tugged a "dead" LWB Transit 200 yards up a hill. Didn't know it was there, even pulled it on creep. .
5th Jan 2016 8:19pm |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 |
Picked fatty up from Green Oval. Ended up having upper and lower bushes replaced on both sides. A little (ha! LOT ) lighter in the wallet but seeing as it took them 5 hours to do cos the bolts were seized I would probably be still at it. And now she has an MOT for another year. Happy days. 😊 |
6th Jan 2016 2:04pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
found a little hidden feature today....... not very exciting, -but, when driving with low winter sun... I often have to play with the sun visors to hide the sun from my eyes. I pull it off its end mount, move it round to side, and often the other side too. and use the extra flap in front. - I like that a lot! however, I thought, -dam, its just not long enough..to hide the sideways sun.. if only it slid out along the swivel bar. -and it does.. just a few inches, but that's enough to carry on driving, without the sun in my eyes!
7th Jan 2016 11:15pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
All I can do is look at mine,fast becoming an ornament for the second xmas period in a row.Needs work and just have no time to do it.Was going to do it over xmas until the workplace got 5 feet of floodwater ! |
8th Jan 2016 9:26pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 899 |
Got a brand new MOT with no advisories! |
9th Jan 2016 10:18am |
xjsracer44 Member Since: 29 Nov 2010 Location: Hertfordshire Posts: 274 |
Also got a brand new MOT with no advisories at 123,456 miles
9th Jan 2016 2:04pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
Opened the sunroof and poured a litre of water down each of the 4 channel drains. Fortunately the water drained out below the car where it's supposed to. One less problem. |
14th Jan 2016 11:48am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
1 new vart i1 battery fitted this morning, the old yausa 3000 over Christmas had been playing up with hdc showing on start up. As I was ill over Christmas for 10 days the ffrr had not been used, so when it was time to go in it next time.....8 volts in the poor battery! After a 48 hour charge I thought all is good and recovered it.....oh how wrong i was, less than 5 days later it was flat again.....down to 0.85 volts! Battery just over 2 years old too, 😠 short trips are a killer for these fatties! If it dont work.......burn it!
14th Jan 2016 12:25pm |
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 |
I didn't actually do anything to it ...
14th Jan 2016 2:05pm |
Don't forget the before and after pictures. |
14th Jan 2016 3:09pm |
Replaced the entire steering column since my old one decided to stop me turning the key in the ignition.
14th Jan 2016 8:54pm |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 |
Removed, vacuumed and cleaned the mats before parcelling safely up until summer and fitted brand new and shiny genuine rubber mats. Was a bit disappointed when they arrived from the dealer in a Ford box though.
14th Jan 2016 9:07pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1656 |
planned a day working on the classic but so damn cold (even in the garage) decided to go to Solihull shopping so used the massive boot to transport a new shirt and a hand bag!. (hand bag's not mine!!) 405 AB exec seats Baltic and Cirrus
15th Jan 2016 6:15pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Decided to replace the glue repaired intake with a replacement from a breaker. Easy 5 minutes, the next hour and a half was getting the broke of spigot un glued from the end of the hose so it could fit on the replacement. Got there in the end.
16th Jan 2016 3:54pm |
