![]() | Home > Technical (L322) > Just Bought A 2011 4.4 TDV8 Vogue SE - few queries |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 ![]() ![]() |
Looks great |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
I did wonder that a few days ago. I've no complaints using them.
Well, I was due to collect it this morning but it's still at Land Rover having a front left solenoid replaced after the fault codes were read yesterday.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2672 ![]() ![]() ![]() |
That's a bastid right enough, just when you're getting fevered up, at least she's getting some love & attention before you collect, sleepless night tonight! |
It was going to be the start of last week, but I've now saved £1500 in interest by finding my own finance for the bit I'm borrowing to change, so between us, it's stretching out a bit. They have also fixed a slight oil leak and a ball joint that were mot advisories.
Baron Member Since: 20 Apr 2013 Location: Nr Drum Castle, Royal Deeside, Scotland Posts: 305 ![]() ![]() ![]() |
Believe me it'll be well worth the wait. |
Looking like Tuesday now as it's still at the dealers having some work done...... 2011 Range Rover Vogue SE 4.4 TDV8
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2578 ![]() ![]() ![]() |
It would be good if that work includes fitting the revised secondary turbo drain pipe if its not already fitted. Its a lot of work and IMO far from a DIY job. |
That's been done already according to land Rovers records. They are fitting a new front left solenoid which was flagging up errors. I think it's suspension related. They have fixed a slight oil leak and replaced a ball joint which were advisories on the mot. 2011 Range Rover Vogue SE 4.4 TDV8
Picked it up this morning and then had issues putting diesel in as I kept triggering the misfuel blocker thing. Seems you can't put the nozzle in as far as you could in the olden days !
Very nice Mark. Ours started being fiddly with the diesel nozzle all of a sudden and I then clocked the yellow protector being visible. Turned out that sometime other than me |
The yellow release thing was in the drivers door pocket, so I'm assuming it needs to be handy !
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8702 ![]() ![]() ![]() |
Best idea with the keys is to buy new covers |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
yours looks similar spec to mine except colour....still you can't have everything |
