Home > Technical (L322) > Just Bought A 2011 4.4 TDV8 Vogue SE - few queries
Page 4 of 4 <1234
mjdronfield
Thanks gents. Looks like I've a few bits to go through.
Not sure the cornering lights come on, and are the headlights supposed to turn also ? I recon that ones a no....
I thought I might have a venture cam, but there is no cam or docking, so must have been an option.
I've just put some DVDs in it so will have a look at the RSE tomorrow.
Is it easy to pair a smart key to the car ? My 2nd one does nothing, even with a new battery. Pm me if you can assist, or is it best left to the dealer ?
I also need to locate a tow hitch key and the locking wheel nut adapter, though that may be with the spare wheel.....
Other than the bits to do, it's epic......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #368348 21st Jan 2016 9:13pm
Trebaix
If filling with fuel still causes blow back insert the nozzle upside down into the car ie turn the nozzle 180 degrees and insert.
Colin
Post #368490 22nd Jan 2016 11:21pm
I think the point is, there should not be the need to turn the nozzle upside down!
If the wrong fuel detector has been triggered then it needs to be correctly reset or it will constantly make the filling a problem...
Mine was triggered by a MASSIVE pothole... Took me three attempts to correctly reset it finally using a very long screwdriver to finish the procedure... Thumbs Up
Post #368493 23rd Jan 2016 12:36am
Page 4 of 4 <1234
