![]() | Home > Technical (L322) > Voltage readings. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Damn!
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
No, it's never that easy, there has to be feedback from the transfer box to confirm it's in high box or it chucks faults up.... Pete
As Haylands says it's unfortunately not that easy but if it finds a problem it will try to engage whatever range it was last set to so you can 'drive to a dealership'. If it fails in High Range then it's probably still useable but in Low Range then you're obviously really limited in driveability. Even if it fails in High Range there is no telling what it might do on the next start up as it checks what it was last set to and cycles the motor if it sees anything different...if it messes up who knows where it might end up including neutral and then leave you stranded so I wouldn't be driving it.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
I'm sorry I don't have time to look at mine or do any research for you as I'm working on my El Niño preparations .
How easy is it to determine what signal it want's, I believe it's a can bus signal so will be a resistance of some kind...
If it's taking a reading from a pot , you can hook up a meter and turn the pot to see the range .
It's been looked into before a few years ago, RRPhil again has done the testing on the potentiometer and someone was going to get the potentiometer manufacturered as it couldn't be found off the shelf but it died a death.
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 ![]() ![]() ![]() |
Good golly
Weil. This kornings findings
My mechanic is coming over today so i will get him to remove the trans box motor and give that a whiz to clean the brushes as detailed in youtube
Aw weil
Unfortunately resetting the adaptions on the Gearbox was probably not a good idea and is why it's doing what it is now (no drive etc.).
Ah reet
Crunching noise is from gearbox.
