![]() | Home > Technical (L322) > Voltage readings. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8518 ![]() ![]() ![]() |
Sounds like alternator to me, you will probably find the battery will need swapping to, they don't like not getting enough charge and sulk a lot....
With those voltage readings whilst driving I think your alternator is failing too. |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
Stick the multimeter on AC and see what you get. My bet is the diodes are failing and causing the current drain also. |
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 ![]() ![]() ![]() |
Thank yer.
Looks like about a 3can 2knuckle job to me..... |
Gawd that has depressed me somewhat
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
Assuming your earth straps are sound, i'd go with faulty alternator too. |
Thank you for all the replies.
Now, I have been reliably informed that the ecu thingy in the drivers footwell can also throw up all the ghost faults that I have been getting.
I am using a plug in volt meter
Due to low voltage I expect, new alternator, charge battery, clear faults and normal service should resume.... |
Thank you for yer time and the pm's
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
The ECU you're talking about is the lighting ECU. In the drivers footwell behind the R/H panel as you say. Usually causes strange indicator/lighting problems. Mine also caused radio/stereo problems when it decided to act up. |
Thanx Stepto, radio???
