Home > Technical (L322) > Air Suspension - a lesson learnt!
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
OK, so over the last year i was having intermittent "air suspension faults". Normally a 'bong' and a loss of light on the centre console [strangely started when turning right!].
Anyway all appeared normal and when restarting it was fine. However the problem became progressively more frequent, until finally every time i switched on and drove for a few mins the 'bong' with suspension fault was given.
A code was extracted and everyone [LR main D + Indy] said my compressor was kaput....
Ordered a new compressor and had it fitted [with software uplift]. It worked for a very short while.....
Further inspection revealed a worn [blue] air supply pipe, worn where it was over part of the chassis.
I am happy to say that having this repaired and the new compressor all is now normal [touch wood].
Post #364811 1st Jan 2016 7:48pm
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
Hello David,
Good you found the Censored thing.
Had my FF on the ramp last week and also found the rear right line hitting the chassis (over the upper suspension attachment). Placed a piece of rubber hose over it.
Can you describe where your blue line was touching the chassis? Might be worth checking that one too.
BR and a Happy New Year to all of you!
Joep
Post #364870 2nd Jan 2016 9:21am
DavidP
Hello Joep,
correct where the piping goes over the rear upper suspension arm. Worn completely through. Cut, reconnected and then reinforced with a rubber hose....
Cheers
Post #364954 2nd Jan 2016 7:55pm
n1cktdv8
is the pipe a 6mm by chance ?
This is the exact same sounding issue I have.....
I'm going to take a look this week, any advice on where to check first and the process of repair? Is this where I put the car details and a bit about myself ?........
Post #364983 2nd Jan 2016 11:17pm
DavidP
Nick,
Yes indeed the pipe is about 6mm and blue. From beneath follow the pipe as it exits the boot, you'll see where it goes over the rear suspension arm.
I will check with the mechanic to see if its before or after the valve.
The repair was simple, cut the pipe either side of the worn part and then use a pneumatic push fit compressed air fitting.
If i can i will get some photos of the repair and position next week.
Rgds
Post #365014 3rd Jan 2016 8:53am
33sport
2007 Range Rover Vogue TDV8 Stornoway Grey
worth checking your brake line too around that area as yesterday after losing all my brake fluid the garage found the brake line worn through directly below the nearside rear seat behind a removable panel, the pipe had worn where it is clipped to the chassis.
the brake line runs parallel with the blue air line at this point too.
Post #365017 3rd Jan 2016 10:04am
n1cktdv8
DavidP wrote:
Nick,
Rgds
Did you repair the existing pipe or add a new piece, I'm going to order some bits off ebay to sort this. Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #365112 3rd Jan 2016 7:30pm
DavidP
Nick,
The existing pipe was cut, about 1cm iirc, and joined. It was then covered with a thick piece of rubber which was secured.
Hope it helps
Rgds
Post #365196 4th Jan 2016 8:50am
n1cktdv8
thick rubber?
Did you sleeve the existing pipe with a larger diameter pipe or wrap and secure it ?
Sorry for so many questions but I'll have limited access to the underside as I am using a friends ramp one night when his garage is closed. Is this where I put the car details and a bit about myself ?........
Post #365205 4th Jan 2016 10:57am
DavidP
I think it was thick rubber. I'm seeing the friend [mechanic] who did it on Wednesday - certainly access was limited, it was up on the ramp, i will try and get photos of it and a very full explanation.
You should have the full run down by Thursday if that's OK.....
Post #365227 4th Jan 2016 12:25pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Just a word of warning, having used the pneumatic push fit connectors many times in the past on air lockers and P38a EAS I have had a couple pop open after time. If its possible get the metal type not plastic ones if you intend to leave the repair permanent or at least carry a spare
[/img] 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #365228 4th Jan 2016 12:26pm
DavidP
n1cktdv8
Sorry for the late reply. I spoke with the mechanic and he confirmed it was over the rear o/s suspension arm. Unfortunately we did not have time to pop it back on the ramp for a photo session.
When the ground warms up here i'll crawl underneath it......
Post #367912 19th Jan 2016 10:37am
n1cktdv8
Thanks Sir.
As an update from my end I had a friend supply stainless push fit valves and got the car on the ramp. There was no leak at all from that area so after a suspension reset and a check of any codes (there were none) we were back to square one.
The car has been two weeks now without a fault and the suspension seems to be behaving itself so I have no complaint....other than the weak battery giving out again and a friend having to assist with his VW amarok Big Cry Is this where I put the car details and a bit about myself ?........
Post #367914 19th Jan 2016 10:44am
DavidP
Great to hear, fingers crossed....
Post #367916 19th Jan 2016 10:51am
