![]() | Home > Technical (L322) > Air Suspension - a lesson learnt! |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 166 ![]() ![]() ![]() |
Hello David,
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
Hello Joep,
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
is the pipe a 6mm by chance ?
Nick,
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 ![]() ![]() |
worth checking your brake line too around that area as yesterday after losing all my brake fluid the garage found the brake line worn through directly below the nearside rear seat behind a removable panel, the pipe had worn where it is clipped to the chassis.
Did you repair the existing pipe or add a new piece, I'm going to order some bits off ebay to sort this. ![]() |
Nick,
thick rubber?
I think it was thick rubber. I'm seeing the friend [mechanic] who did it on Wednesday - certainly access was limited, it was up on the ramp, i will try and get photos of it and a very full explanation.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 ![]() ![]() ![]() |
Just a word of warning, having used the pneumatic push fit connectors many times in the past on air lockers and P38a EAS I have had a couple pop open after time. If its possible get the metal type not plastic ones if you intend to leave the repair permanent or at least carry a spare
n1cktdv8
Thanks Sir.
Great to hear, fingers crossed.... |
