Home > Technical (L322) > Air Suspension - a lesson learnt! |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 163 |
Hello David,
2nd Jan 2016 8:21am |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
Hello Joep,
2nd Jan 2016 6:55pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
is the pipe a 6mm by chance ?
2nd Jan 2016 10:17pm |
Nick,
3rd Jan 2016 7:53am |
33sport Member Since: 24 Jul 2015 Location: kent Posts: 82 |
worth checking your brake line too around that area as yesterday after losing all my brake fluid the garage found the brake line worn through directly below the nearside rear seat behind a removable panel, the pipe had worn where it is clipped to the chassis.
3rd Jan 2016 9:04am |
Did you repair the existing pipe or add a new piece, I'm going to order some bits off ebay to sort this. Is this where I put the car details and a bit about myself ?........ |
3rd Jan 2016 6:30pm |
Nick,
4th Jan 2016 7:50am |
thick rubber?
4th Jan 2016 9:57am |
I think it was thick rubber. I'm seeing the friend [mechanic] who did it on Wednesday - certainly access was limited, it was up on the ramp, i will try and get photos of it and a very full explanation.
4th Jan 2016 11:25am |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 791 |
Just a word of warning, having used the pneumatic push fit connectors many times in the past on air lockers and P38a EAS I have had a couple pop open after time. If its possible get the metal type not plastic ones if you intend to leave the repair permanent or at least carry a spare
4th Jan 2016 11:26am |
n1cktdv8
19th Jan 2016 9:37am |
Thanks Sir.
19th Jan 2016 9:44am |
Great to hear, fingers crossed.... |
19th Jan 2016 9:51am |
