Home > Maintenance & Mods (L322) > Strange Ignition fault
mpirie
Hi guys,
Strange one for Christmas. 2008 TDV8 Vogue. Battery drained to the point where it wouldn’t start the car (doors open, lights on etc) anyway, disconnected the battery, charged it up overnight (should say it’s a Bosch S5 019 about 2yrs old).
This morning, reconnected the battery, and started her, no problem. Left her running for 10-15 mins. Turned her off and now neither key will turn in the ignition lock, unless I disconnect the battery and go through the same routine. I checked with my IIDTool and got the following errors: "Magnetic driver open circuit or short to ground”, “Securing magnet fault” and "Locking operating error”.
Anyone seen these errors before?
Mike
Post #363151 20th Dec 2015 9:57pm
Try another battery disconnect procedure... Thumbs Up Pete
Post #363162 20th Dec 2015 10:35pm
Bin the battery!
Changed almost every Bosch S5 I’ve ever seen on a FF as they do seem to fail often... Rolling Eyes
I personally would only ever fit a JLR battery sir Bow down
Post #363189 21st Dec 2015 1:04am
mpirie
Thanks Pete.....that was the only way I could get her restarted......disconnect - reconnect procedure.
Craig - that's interesting since the battery has a 5 year guarantee.....seems little point putting another S5 in if it's going to fail again! Big Cry
Mike
Post #363207 21st Dec 2015 7:24am
mpirie
Well, replaced the battery earlier today (thanks to a 5 year warranty from Bosch) and guess what?
Correct......no difference.
I did the steering wheel reset but the only way i can get the key to turn in the ignition is to disconnect/reconnect the battery.
Something's throwing the errors up and despite clearing them with IIDTool, they come back.
Most frustrating !
Mike
Post #363529 22nd Dec 2015 7:56pm
mpirie
I take it no-one has seen these errors before then?
Looks like i need to book her into the Landy Doctor. Big Cry Big Cry Big Cry
Post #363943 25th Dec 2015 12:18pm
Did they check the battery & confirm it was dodgy before replacing it ?
Was the new battery fully charged before fitting it ?
Post #363944 25th Dec 2015 1:34pm
mpirie
Hi Alistair,
Yes to both questions I'm afraid.
If I reconnect the battery, she'll start and I can switch her of and on as often as I like, but once I remove the key, that's me screwed until I disconnect/reconnect again.
Even though I clear the codes with my iidtool, they come back again.
Running out of ideas now.
Mike
Post #363960 25th Dec 2015 4:53pm
Sounds like some kind of problem with the ignition switch - and it's keeping other things running which may have screwed up your battery.
Time to take it to someone who knows what they are doing.
Post #363967 25th Dec 2015 9:21pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Slightly weird one as I thought they did away with the steering column lock on the '08 models along with the key but check this thread out in case yours is an '07 and late registered:
http://www.rangerovers.net/forum/6-range-r...ealer.html
It sounds like a steering lock problem as the magnetic lock error codes and the symptoms are the same as suggested above.
The basics as I understand it are:
The solenoid that locks the steering column can unlock the column with the key first placed in but due to the solenoid failing or getting sticky it can't lock it again when the key is removed and throws up an error. The next time you place the key in it won't even attempt an unlock as the error is present. If you remove the power to the steering column ECU (either by battery disconnect or remove fuse 18 that supplies the column ECU) then it resets itself and you can use the key again.
It seems the dealer fix is a new steering column as the column solenoid or ECU (which can also give issues) are not available separately.
There are some DIY fixes or repairs. Removing fuse 18 and replacing every time or wiring in a switch which does the same is a get around. You can also modify the steering column and drill a hole through to the solenoid and apply lubrication , the lack of which is often why the solenoid sticks. Details of this fault and procedure are explained here: http://www.blackbox-solutions.com/photos/L322lock.pdf
This is assuming that is your issue, try removing and replacing fuse 18 in the meantime and seek out a proper diagnosis with someone who knows what they are doing!
Post #363998 26th Dec 2015 9:59am
mpirie
Thanks guys, it does sound like the steering lock as mentioned above, I'm just not a fan of coincidences........it's been working fine until last week when the battery drained.
Mike
Post #364004 26th Dec 2015 10:42am
A faulty ignition switch can keep the electrics running
I would be putting the battery failure down to that rather than the other way around
Be careful that it doesn't drain the new one
Post #364005 26th Dec 2015 10:50am
Just out of curiosity, Have you tried a spare key to see what happens?
Post #364011 26th Dec 2015 11:16am
When you put the key in, before you turn it, you should hear a solenoid disengage the steering lock. It works on the immobiliser transponder in the key.
If you can't hear that or you hear a clicking noise like it trying to disengage, then you have narrowed down the culprit somewhat. What does it sound like when you do it the first time after a reset? There is nothing that can't be fixed with a hammer😜😜
Post #364013 26th Dec 2015 11:24am
mpirie
First thing i did was try the spare key......it has the same result, so not likely to be the key transponder.
After a reset, i can hear the lock come off when i insert the key.......and providing i leave the key in, then, no problem.
It's only when i remove the key that the lock comes back on, but won't go off if i reinsert either key again.
I can clear the codes with IIDTool, but they come back again as soon as i remove the key.
Mike
Post #364025 26th Dec 2015 3:48pm
