![]() | Home > Maintenance & Mods (L322) > Strange Ignition fault |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 910 ![]() ![]() ![]() |
Yep, looks like the steering lock ECU. I replaced fuse 18 with a switch and that's my temporary work around.
davrr Member Since: 08 May 2012 Location: central scotland Posts: 25 ![]() ![]() ![]() |
Looks like I may have to do the same thing , have abandoned it at present in the driveway , will try to do some more research in the next few days and deal with it in the new year. |
In the meantime, to avoid constantly disconnecting/reconnecting the battery, you can pull fuse 18 behind the glove box and reinsert it to perform the same function, or replace it with a fused switch. |
Thanks for that Mike , will give it a try.
When I get my new column installed, I may have the switch solution available for you if you want it |
That would be great , Thanks. |
