![]() | Home > Maintenance & Mods (L322) > Strange Ignition fault |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Try another battery disconnect procedure... |
Bin the battery!
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 904 ![]() ![]() ![]() |
Thanks Pete.....that was the only way I could get her restarted......disconnect - reconnect procedure.
Well, replaced the battery earlier today (thanks to a 5 year warranty from Bosch) and guess what?
I take it no-one has seen these errors before then?
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7971 ![]() ![]() ![]() |
Did they check the battery & confirm it was dodgy before replacing it ?
Hi Alistair,
Sounds like some kind of problem with the ignition switch - and it's keeping other things running which may have screwed up your battery.
Weejock Member Since: 30 Dec 2011 Location: UK Posts: 418 ![]() ![]() |
Slightly weird one as I thought they did away with the steering column lock on the '08 models along with the key but check this thread out in case yours is an '07 and late registered:
Thanks guys, it does sound like the steering lock as mentioned above, I'm just not a fan of coincidences........it's been working fine until last week when the battery drained.
A faulty ignition switch can keep the electrics running
Just out of curiosity, Have you tried a spare key to see what happens? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
When you put the key in, before you turn it, you should hear a solenoid disengage the steering lock. It works on the immobiliser transponder in the key.
First thing i did was try the spare key......it has the same result, so not likely to be the key transponder.
