![]() | Home > Maintenance & Mods (L322) > Reverse lamp upgrade bulbs? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
![]() ![]() I still find it hard to come to terms with how they managed to get it so wrong with the reversing lights in the first place, after all your allowed 21 Watts per side under euro meddling laws, so why opt for 6 watt bulbs? they must have had a balls up in the purchasing department and ended up with a lorry load to get rid of......... only logical reason I can see ![]() ![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16318 ![]() ![]() ![]() |
Great job Dave... Much brighter |
The bulbs I purchased were from Hong Kong and took two weeks to arrive.
^^ 12v AC is for low voltage domestic lighting, and will have a built in bridge rectifier |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Unnecessary quote removed
Just bought the 5w version (says 6 but it's 5w on eBay). Wanted to go the cob route since I think it will be a bit brighter than the little leds. The entire length of these are 40mm so they should fit fine. Now just need the washers and G4 sockets
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
So after 216 posts we still don't have a simple plug and play mod, we have all failed but not through lack of trying 😃😃😃😃 Many thanks
I can do a simple plug and play version, but, I will have to buy the lamps from Land Rover |
Cheapest and best option is send the Misses round the back with a big torch then 👍👍 Many thanks
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 ![]() ![]() ![]() |
No point my misses is only 5" so no improvement over the car |
Jeese 5" what's here name Barbie 😜😜😃😃😜😜 Many thanks
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 ![]() ![]() ![]() |
Miggit, what about a used donor first set, then do a buy and return your old set deal |
I did think of that, but having found that they can get brittle, discoloured and cracked with age, it would be impossible to guaranty the quality, and would therefore be laying myself open to "I want my money back as my lights were better than the ones you've sent".
Points taken |
