Home > Technical (L322) > L322 VANOS solenoid |
tymh Member Since: 21 Apr 2014 Location: Garstang Posts: 312 |
Out of curiosity and I've looked into this, and found a 1.6 Laguna...
11th Dec 2014 9:43am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
either throw your existing policy over to 'new' car, or pay monthly.... |
11th Dec 2014 12:53pm |
is this the same as this more expensive version ?
12th Dec 2014 11:16am |
The trick to anything like this is knowing one's limitations... this, in all honesty, at the present time, is totally beyond me! So... found a local garage who know what they're doing (and were the only ones to ask if it was gassed as that increases the time needed!) and it's being picked up on 5 Jan - should have it back later the same week.
15th Dec 2014 11:58am |
i think you made a very good decision. watch out for any water leaks after, and small oil leaks too. |
16th Dec 2014 9:33am |
Choppergrino Member Since: 29 Nov 2015 Location: Melbourne Posts: 14 |
Hi guys,
29th Nov 2015 10:20am |
at the least you should fill it with oil, listen, and compare the noise at idle, to what people have posted on youtube, say 'vanos rattle m62tu44 engine' they do have a clatter when idling if they are bleeding past the seals. perhaps post your sound on youtube and post here..
29th Nov 2015 12:36pm |
Thank you John I will definitely give your ideas a go. 👍🏻 |
29th Nov 2015 7:37pm |
Just recalling.... If you were to first remove the tensioner, check it has some Spring tension, and does any oil run out? Gues it went in dry.... Can't remember what I read up back then, but it must be spring loaded at rest, and under hydraulic pressure at idle. But it could be jammed in its 'squashed in ' position.
29th Nov 2015 11:09pm |
Yes John I did install an new tensioner and it wasn't pre-loaded, I have a feeling this may be the issue. I will celebrate with the tinnys after the car purrs
30th Nov 2015 1:38am |
was just thinking again.....some people have in the past, had difficulties with the oil filter re-inserting., if done wrong, it could hinder oil pressure. you could check that it has now refilled itself, -and, that it empties when you lift the filter up etc. as sometimes these jam, or go in upside down! |
3rd Dec 2015 8:37am |
Thanks John I will check it out, hoping to get out and have a look at the car next Monday. Keep you posted |
3rd Dec 2015 11:43am |
Does anybody have a close up of the tensioner and which way it should be installed? I installed it with the plunger to the guide. As for preloading the tensioner I am guessing submersing it in oil and pumping it till it gets firm? thanks Danny |
4th Dec 2015 7:26pm |
cant help with pictures of mine, but did you read this. it is very long, but its what i used.
4th Dec 2015 7:35pm |
