![]() | Home > Technical (L322) > Smokey L322..! HELP! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35499 ![]() ![]() |
it would be helpful if you filled in your car profile so we can see what model variant you have.. ... - .- -.
donnyvikings Member Since: 25 Nov 2015 Location: Doncaster Posts: 3 ![]() ![]() |
I did on registration, cars a Td6 on a 2004.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Hi - just so your car details appear under your name for your future posts (like they do on LHS column on Stan's and my post here), go to your profile and fill in car details.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
The 'liver' you describe sounds like it can be from a type of fungus that grows in Diesel (heating oil and parafin too).
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3246 ![]() ![]() ![]() |
I wonder also if the injector cleaner has removed the gunge from around the seals and they are now leaking.
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 ![]() ![]() ![]() |
has the breather on the engine been changed, when they block it causes oil to be forced by the seals causing smoke, if it hasnt get the new vortex type. |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 463 ![]() ![]() ![]() |
A quick way to see if the engine is breathing ok, filter not blocked. With the engine running, remove the oil filler cap. There should be little to no back pressure. You may have a little smoke, but not too much. When the filter is blocked bad you will hear a hiss as you remove the oil filler cap. Seek help immediately if this is the case as the back pressure stops oil return from the turbo and will cause turbo failure. As Arron says the new vortex one is better,also not a big job to change. |
Hi thanks guys, all great info coming. I've checked my profile and my cars info is there, so not sure how to make it public? Looked at the filter and all seems good, No blowback. Car has run for an hour today with no smoke.....then after restart at paper shop...it was back! Sticky injector? |
to make the car profile work you must have all the drop down menus filled in.. ... - .- -.
