Home > Technical (L322) > wheel bearing
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
wheel bearing
Ok lads, I've read up on quite a few topics and peeps who have attempted the front wheel bearings.
now does anyone know if the air strut has to be deflated?. Or is it a case of letting it hang when undone.
Would be very grateful for any advice or opinions. Have also read my workshop rave and it doesn't say anything.
cheers in advance. Thumbs Up
greg.
Post #357531 18th Nov 2015 8:40am
Doesn't need deflating... Thumbs Up Pete
Post #357533 18th Nov 2015 8:50am
fisha
Jack up and prop the chassis, then you can also put a jack or stand under the hub to bear a little bit of the weight so that it stays in place better. If the strut and hub just hang, they can move about a bit when trying to put force on nuts and bolts. V8 or else ...
Post #357542 18th Nov 2015 10:10am
gregdav
Thank you lads. Will probably have a go myself then.
I've got the bearing circlip and hub nut and was deciding weather to get a new knuckle and save the hassle of getting the old bearing out.
I've also seen a bearing dust shield, is this needed ?. And is it wise to have new bolts for the strut to hub.
Thanks again.
Greg. Thumbs Up
Post #357547 18th Nov 2015 11:07am
New bolts are essential as they will almost certainly be seized and need a huge whack to move them!!! SO, with that in mind! Think twice about your abilities before you tackle such a task sir!
You will then have to remove and refit the drive shaft from the hub! That in itself can be a HUGE task dependant an how seized/corroded it is and your ability sir...
PLEASE don’t think I’m trying to put anyone off their own maintenance guys... Just trying to let the OP know the severity of this task... Thumbs Up Bow down Bow down Bow down
Post #357552 18th Nov 2015 11:29am
gregdav
Thanks for the heads up craig. I may use an indy I have known quite a few years. Have given him a call and he said he had done one only yesterday took them about 3/4hrs all depends how it comes apart.
so worst case scenario could be upto £150 labour.
Post #357584 18th Nov 2015 1:28pm
As Craig says, getting drive shaft out is a pain,
getting it back in without the proper tool is virtually impossible... Pete
Post #357585 18th Nov 2015 1:33pm
