Home > Technical (L322) > wheel bearing |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8203 |
Doesn't need deflating... Pete
18th Nov 2015 8:50am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
Jack up and prop the chassis, then you can also put a jack or stand under the hub to bear a little bit of the weight so that it stays in place better. If the strut and hub just hang, they can move about a bit when trying to put force on nuts and bolts. V8 or else ... |
18th Nov 2015 10:10am |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Thank you lads. Will probably have a go myself then.
18th Nov 2015 11:07am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
New bolts are essential as they will almost certainly be seized and need a huge whack to move them!!! SO, with that in mind! Think twice about your abilities before you tackle such a task sir!
18th Nov 2015 11:29am |
Thanks for the heads up craig. I may use an indy I have known quite a few years. Have given him a call and he said he had done one only yesterday took them about 3/4hrs all depends how it comes apart.
18th Nov 2015 1:28pm |
As Craig says, getting drive shaft out is a pain,
18th Nov 2015 1:33pm |
