![]() | Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins..... |
andrew.aa Member Since: 16 Aug 2011 Location: PERUGIA Posts: 102 ![]() ![]() ![]() |
sorry for the delay, but these days are full of problems .. even the automatic transmission of my Skoda 4x4 stuck in 1st after 120000km.and need replace gearbox..
wandering the web I noticed ebay item eBay Item No. 321835906452 for RECONDITIONED ZF5HP24 from a UK seller, but invoice show repair service for a GM 5140e, ie diesel X5.. |
today gearbox refitted with same problem, (between 1st and 2nd , lost drive for a second and bang..) so at this point I give up, because became very hard. If anyone have an idea I here ..
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Andrew, your story is very dissapointing. a sad ending..
Yes John, really sad ending ..about transmission thanks for check and interest, but is a little expensive for my opinion, anyway good.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1000 ![]() ![]() |
The outer race of the one-way (sprag) clutch should rotate clockwise (but not anticlockwise) when the F-clutch drum is held stationary.
Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Thanks Phil, but I'm not sure what mean with ''the collar at the top'' .
Phil, why in R position lever, MV1 is ON and MV2 is OFF? |
Yes, your photo is correct. The red arrow is pointing to the collar
Something definitely wrong there. The inner race should only rotate clockwise and should lock solid if you try to turn it in the other direction. 1st gear in automatic mode (Drive) will not work if it doesn't lock. If you engage 1st gear in Manual mode, however, then the F-brake is applied which will bypass the sprag. In other words, if the engine just revs in Drive when stationary (as if in Neutral) but will set off in Manual 1st gear then there is an issue with the sprag. Phil |
I've just checked some measurements that I took from my transmission using the Faultmate and it's identical to yours. MV1 is on and both MV2 & MV3 are off in Reverse. I need to investigate this further - it certainly doesn't stack up with the early ZF literature. Strange. Phil |
Sorry to be banging on about this yet again but it’s so common to see - just like in this eBay listing - a 5HP24 transmission being sold as suitable for both the Range Rover and the BMW X5. This is incorrect. The E53 and L322 have different transfer boxes so the output shaft and mounting flange are different on the two transmissions. The L322 uses a ‘long’ output shaft and the E53 uses a ‘standard’ output shaft (as used in RWD BMW and Jaguar models) but with a separate extension shaft.
Only the ‘032’ model (i.e. model number 1058 000 032) of the 5HP24 will fit the L322. A ‘029’ or ‘034’ model from a 4.4i or 4.6is BMW X5 will not fit the L322. My apologies for the rant – it just winds me up ![]() Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
I want to make the point of the situation.
this is not very clear to me, but as I understand from your words, in drive mode should not have the 1st but only in manual mode, because the sprag is bypassed, but I can engage the 1st in dive mode and also in manual mode . About ebay transmission fo X5, you were right to point out the differences between models, even though I had read all of your posts in others Bmw Jaguar, Audi and of course, Land Rover forums, where you have explained many times this concept. However I do not intend to take another automatic transmission. Yesterday, as I was starting remove the transmission another time, I noticed that from sump plug, came out only just three liters of oil. This makes me think that as John said, could have a low fluid level. tough I put about about seven liters, and torque converter was filled. symptom are: Reverse work property. engagement 1ST drive mode or manual mode is the same: at idle speed no problem, when accelerate, seems to lose traction (as in neutral) and came back with a shot, if I leave accelerator. and trans failsafe prog appears. John can you please explain me your symptoms with low fluid level. |
my symptoms of low fluid level, were, slight gurgle on first start up. (not sure if it was directly related) refilled again. -then drove off ok, but slipping when trying to go 1- 2 and maybe a bang into gear, or straight to 4th, and transfail bong.! and again slipping gurgling noise. i topped up to what i thought was full, and it was better, drove ok, but it did same 1-2 slipping, when i turned right, this i thought had to be low fluid. -i returned from journey, and raised car into offroad height, (completely level car now....) and slid under to try and refill with syringe method. it took some more.
ok, yesterday, I refilled trans with 4,5/lt of atf and the problem is the same. the method was different and I put plastic pipe to the oil radiator on front and filled with 12v electric pump,
