Home > In Car Electronics (L322) > 2012 Audio quality
Page 2 of 5 <12345>
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Just drove up to London. Rubbish audio quality from all sources. But the sat nav voice has great quality. Deep base and full tone even on low volume. Very frustrating. Any ideas? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #344883 28th Aug 2015 2:45pm
nobbyclark
I have the L7 setup and have to turn down the sub otherwise various bits of interior trim resonate in time to the music.
Post #344888 28th Aug 2015 3:17pm
Herdwick
Same here, with the volume turned up, you can 'feel' the music through the car seat, interior mirror vibrates.
Sub volume is set to about half.
Post #344954 29th Aug 2015 9:15am
ebajema
This just doesn't make sense. My 2010 5.0 SC has a brilliant sound system. I have to turn the bass/sub down a lot otherwise it is too much. It should be identical to your system as mine was in the 2010-2012 range and also has the premium sound system.
There must be something wrong with the system somewhere, either software, amp hardware or wiring. MY 2010 5.0 SC Galway green and sand interior!!
Post #344983 29th Aug 2015 11:52am
Nomad
That's what I said to the dealer. They checked it out, they said, and supposedly did a software update. It was a bit better. When on high volume it's ok but low down there's nothing. My workaround is to skew the fader to the back and turn up the volume. No good if anyone else is in the car as it's too loud at the back but allows fuller sound up front. Still not happy - I'll raise it with the dealer again next time it's in. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #344992 29th Aug 2015 12:27pm
chdavis
2012 Range Rover Autobiography 5.0 SC V8 Galway Green
I know this is an old thread, but I have the same issue happening. Did you ever work it out?
Post #614526 3rd Dec 2021 12:21am
Nomad
No. That was the best I could do. Eventually sold the vehicle . Not because of the sound system just couldn't justify a 5L supercharged anymore. Big Cry 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #614532 3rd Dec 2021 7:25am
Bl4ckD0g
Netherlands 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
Maybe someone has wired something in over time, try and short the aux input (use an old 3.5mm jack and just cut off the wires...). Then plug it in the rear aux input.
It sounds like it thinks it is in sound mixing other source overlay mode if Satnav notifications are good...
Post #614539 3rd Dec 2021 8:57am
chdavis
Thanks mate. I appreciate you coming back on to let me know. I’ve replaced the amp, and directed my dealership to fix it without regard to expense but we are all out of ideas. They think I’m crazy.
Post #614602 3rd Dec 2021 4:11pm
chdavis
I am willing to replace the speakers from a 2010 or older but I don’t want to create more problems.. 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
2020 Tesla Model 3 Performance, 2013 Mercedes-Benz G550, 2008 Ferrari F430, 2007 Volkswagen Touareg V10 TDI
Post #614603 3rd Dec 2021 4:13pm
Bl4ckD0g
Crazy for what? The problem you hear? Or letting them fix it without regard to expense? With the latter I can agree, dealer don't tend to be great at trouble shooting or repair, in my experience they tend to just swap parts.
Have you or them done the basics and used an SPL meter to verify what you are hearing? As I mentioned already, if the Satnam instructions sound good and full then I suspect something is interfering with your aux signal...I wouldn't swap out anymore parts...
Post #614605 3rd Dec 2021 4:19pm
chdavis
What is an SPL meter and how do I use it? Or at least what term should I Google where I can find out 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
Post #667963 30th Jun 2023 1:33pm
SPL stands for 'sound pressure level'
its a sound audio meter. ... - .- -.
Post #667968 30th Jun 2023 2:08pm
chdavis
Thank you! That’s helpful 2012 Range Rover HSE | 2011 Range Rover Autobiography | 2010 Range Rover Sport Supercharged
Post #667972 30th Jun 2023 2:27pm
JayGee
You can also buy fairly cheaply a calibrated microphone and frequency analyser to see what areas of the sound are missing. A sound pressure meter won't give you anything but the dB reading. Lack of bass can be caused by speakers wired 'our of phase'. 2012 TDV8 Vogue (L322)
Post #668129 2nd Jul 2023 11:17am
Page 2 of 5 <12345>
