![]() | Home > Technical (L322) > Engine management fault |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Nice one, glad it's an easy fix. |
Bungal Member Since: 27 Dec 2013 Location: Hartley Posts: 44 ![]() ![]() ![]() |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8747 ![]() ![]() ![]() |
Saw your post in the general section, If you have mail ordered the silicone hoses, then get some of the Harris tape from halfords, will hold under normal driving a lot better than the gaffer tape. There is nothing that can't be fixed with a hammer😜😜
Thanks for the advice
And that is the right approach with JLR products : always a challenge |
Changed the top two hoses this morning then took it out for a good thrash.
Nice work. |
Top job, the lower ones are a bunch more involved to swap over, and don't often fail. It's usually just the top RH one as you look at the engine where it bends |
That's the that split on mine |
