Home > Technical (L322) > Drivers Memory Function ?? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8330 |
Disconnecting the battery won't upset anything else apart from the clock... it's worth a try but don't hold your breath... see the procedure for battery disconnect in the WIKI Pete
15th Aug 2015 12:22pm |
Ianmaney Member Since: 27 Nov 2012 Location: Birmingham UK Posts: 118 |
Cheers Pete, nothing ventured............ Semper in merda sumus, solum altum variat !!
15th Aug 2015 6:32pm |
apole Member Since: 27 May 2015 Location: Berkshire Posts: 29 |
Dunno if this helps but thought mine wasn't working correctly.
21st Aug 2015 9:53am |
If you have the door open and ignition off it will move to the memory position with one touch of the button, if the door is shut or you have the ignition on you have to press and hold the button... it's to stop a one shot move whilst driving... could be dangerous... Pete
21st Aug 2015 9:58am |
Thanks,
21st Aug 2015 10:01am |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
now I know why Regards Mark 2012 Westminster GONE - 2007 Java Black FF Vogue, with Ivory interior |
21st Aug 2015 10:12am |
Nope, no luck with mine, its just given up Semper in merda sumus, solum altum variat !!
23rd Aug 2015 7:15pm |
It seems the ECU is inside the drivers seat switch pack.... plenty on ebay
23rd Aug 2015 11:02pm |
