Home > Technical (L322) > Lower Tailgate damper
IanT599
Hi all,
On cars fitted with the damper does it actually do anything or does the lower tailgate still slam down if you just open it and let go.
I thought the damper slowed the tailgate dropping. Garage said I'm talking nonsense.
Post #340994 6th Aug 2015 2:01pm
Sounds like you need the "rear tailgate damper mod" Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #341001 6th Aug 2015 2:42pm
IanT599
Already got the damper fitted as my11. Just doesn't seem to do anything.
Post #341004 6th Aug 2015 2:44pm
hmm, could be a duff damper then? Got - 2017 SDV8 Autobiography in Loire Blue
Post #341006 6th Aug 2015 2:45pm
CS
I'd say it does slow it down a bit. I recall the undamped tailgate would drop and bounce off the stops if one just let go of it. I don't think the damped one does that. Only Range Rovers since 1988
Post #341007 6th Aug 2015 2:51pm
Zirconblue
i think youve answered your own question. you need a new damper your old one is clearly faulty.
Post #341010 6th Aug 2015 3:18pm
miggit
Your damper is fubar'd, when it's working correctly the tail gate still drops at a rate, only you don't get the thud and the bounce. It does not lower the tailgate slowly, like a cassette door or some other house hold item.
The best way to check is remove the damper and first pull it all the way out then, push it back in again, if it's working then there will be some resistance half way towards the end of the stroke.
Oh and after extensive research, I found that it was fractionally cheaper to buy from the stealers Shocked It all looks promising until you add the carriage in to the price. If you have a stealer with in 10 miles of you I'd go there Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #341012 6th Aug 2015 3:29pm
Muttley
United Kingdom 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I had a damper fitted to mine by Cam Tech and I certainly didn't regret it Thumbs Up
Cheers
Dave Current : 4.2 S/C, now Sold Sad
Previous : V70 Volvo, S40 Volvo ( a very reliable old banger ), E39 M5, Carlton Diplomat and the list goes on Smile
Life Sucks but ya just have to do the best you can with what you have !
Post #341066 6th Aug 2015 10:33pm
Your damper may be fine but you have a duff installation, it's happened before where the bracket is fitted out of position slightly and the strut doesn't get enough stroke as it were to work properly . 2008 MY Supercharged
Post #341103 7th Aug 2015 7:49am
miggit
Axle buddy, the man has a 2011 ffrr, I'm under the impression that it was standard factory fit by then Wink
But if it is a retro fit, you have a valid point, the damper needs to be as close to the bottom edge of the tailgate as possible with out fouling. This gives the damper a fighting chance to effect the fall of the tailgate, the more in board the damper (nearer to centre line of the hinges / closer to you when open) the greater the force in has to deal with. And as some have discovered, there is a point at which it has no effect Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #341107 7th Aug 2015 8:21am
wealy
A new one from Dan is about 16 quid delivered!
Post #341130 7th Aug 2015 10:10am
wealy
And fitted in about 2 minutes!
Post #341131 7th Aug 2015 10:10am
As above - on mine the tailgate would kind of drop, but the damper would catch it & stop it slamming - the last ⅓ of the drop was slowed substantially
If it slams - it's wrong
Post #341132 7th Aug 2015 10:22am
IanT599
Mine came from factory with it fitted. It bounces off of the bumper if I let it go.
If I lower it manually just slower than free fall speed I can feel the damper partially kick in.
Dealer is adamant it is fine cause if it wasn't working they'd have to replace it at their cost. Not surprised they say it works.
Just cannot believe they are arguing over a few pounds. I'll have to probably do it myself as they say not covered under warranty.
Post #341939 11th Aug 2015 11:51pm
Zirconblue
It will probably be argued as "wear and tear" as a warranty issue. If this is a jaguar warranty I would raise it as an issue with Jaguar customer services directly. It seems obviously faulty to me.
Post #341940 11th Aug 2015 11:56pm
