![]() | Home > Technical (L322) > Lower Tailgate damper |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6769 ![]() ![]() ![]() |
Sounds like you need the "rear tailgate damper mod" |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Already got the damper fitted as my11. Just doesn't seem to do anything. |
hmm, could be a duff damper then? Got - 2017 SDV8 Autobiography in Loire Blue
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1403 ![]() ![]() ![]() |
I'd say it does slow it down a bit. I recall the undamped tailgate would drop and bounce off the stops if one just let go of it. I don't think the damped one does that. Only Range Rovers since 1988 |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
i think youve answered your own question. you need a new damper your old one is clearly faulty. |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Your damper is fubar'd, when it's working correctly the tail gate still drops at a rate, only you don't get the thud and the bounce. It does not lower the tailgate slowly, like a cassette door or some other house hold item.
Muttley Member Since: 21 Apr 2013 Location: Heathrow Posts: 536 ![]() ![]() ![]() |
I had a damper fitted to mine by Cam Tech and I certainly didn't regret it |
Your damper may be fine but you have a duff installation, it's happened before where the bracket is fitted out of position slightly and the strut doesn't get enough stroke as it were to work properly . 2008 MY Supercharged
Axle buddy, the man has a 2011 ffrr, I'm under the impression that it was standard factory fit by then |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
A new one from Dan is about 16 quid delivered! |
And fitted in about 2 minutes! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
As above - on mine the tailgate would kind of drop, but the damper would catch it & stop it slamming - the last ⅓ of the drop was slowed substantially
Mine came from factory with it fitted. It bounces off of the bumper if I let it go.
It will probably be argued as "wear and tear" as a warranty issue. If this is a jaguar warranty I would raise it as an issue with Jaguar customer services directly. It seems obviously faulty to me. |
