Home > Technical (L322) > Lower Tailgate damper |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6719 |
Sounds like you need the "rear tailgate damper mod" Got - 2017 SDV8 Autobiography in Loire Blue
6th Aug 2015 1:42pm |
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 |
Already got the damper fitted as my11. Just doesn't seem to do anything. |
6th Aug 2015 1:44pm |
hmm, could be a duff damper then? Got - 2017 SDV8 Autobiography in Loire Blue
6th Aug 2015 1:45pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1373 |
I'd say it does slow it down a bit. I recall the undamped tailgate would drop and bounce off the stops if one just let go of it. I don't think the damped one does that. Only Range Rovers since 1988 |
6th Aug 2015 1:51pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
i think youve answered your own question. you need a new damper your old one is clearly faulty. |
6th Aug 2015 2:18pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Your damper is fubar'd, when it's working correctly the tail gate still drops at a rate, only you don't get the thud and the bounce. It does not lower the tailgate slowly, like a cassette door or some other house hold item.
6th Aug 2015 2:29pm |
Muttley Member Since: 21 Apr 2013 Location: Heathrow Posts: 536 |
I had a damper fitted to mine by Cam Tech and I certainly didn't regret it
6th Aug 2015 9:33pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Your damper may be fine but you have a duff installation, it's happened before where the bracket is fitted out of position slightly and the strut doesn't get enough stroke as it were to work properly . 2008 MY Supercharged
7th Aug 2015 6:49am |
Axle buddy, the man has a 2011 ffrr, I'm under the impression that it was standard factory fit by then
7th Aug 2015 7:21am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
A new one from Dan is about 16 quid delivered! |
7th Aug 2015 9:10am |
And fitted in about 2 minutes! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7921 |
As above - on mine the tailgate would kind of drop, but the damper would catch it & stop it slamming - the last ⅓ of the drop was slowed substantially
7th Aug 2015 9:22am |
Mine came from factory with it fitted. It bounces off of the bumper if I let it go.
11th Aug 2015 10:51pm |
It will probably be argued as "wear and tear" as a warranty issue. If this is a jaguar warranty I would raise it as an issue with Jaguar customer services directly. It seems obviously faulty to me. |
11th Aug 2015 10:56pm |
