Home > Wheels & Tyres > LandRover jacks are dangerous and completely useless !! |
Mustard Member Since: 25 Jun 2013 Location: North of South Posts: 299 |
After much reading and faffing I see why the sprinter one is what people generally go for:
1st Aug 2015 5:15pm |
If you trawl the forum you will see someone that took a grinder, ground of the horns and made it rectangular. Then glued a rubber layer on top and it fits the hole as well.
2nd Aug 2015 2:09am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
They probably just have an account with a courier, and that's what the courier quotes them. It's not worth their hassle to find another carrier just for you. I've had a look at their jacks, they're nothing special, just the generic Chinese made ones you can get anywhere. There must be somewhere in Australia that sells them. If it comes to it, how much does a Mercedes dealer charge for a replacement jack for a Sprinter van? |
8th Aug 2015 8:38am |
I got my Merc jack the other day, went outside in the rain and jacked up the motor with it, very happy with its performance
8th Aug 2015 8:50am |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
The jack on the sprinter van is located under the passenger footwell of the van and is lay on its side from new so it will be fine lay down in a RR. Agueroooooooooo. 93-20 I swear you will never see anything like this ever again....watch it..drink it in. |
8th Aug 2015 9:29am |
In view of the scathing criticism of the Range Rover scissor jack and it suitability for use on such a heavy vehicle, has anyone had any feedback from Land Rover on the subject? Also is the jack supplied with the new l405 any better suited to its purpose? Agueroooooooooo. 93-20
8th Aug 2015 9:33am |
The sprinter jack is fine stored laid on it's side, as has been said, it's how it's stored in the vans.
8th Aug 2015 9:37am |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
The L405 jack looks as weak as the L322 one. The car is 450kg lighter though. |
8th Aug 2015 12:49pm |
to my knowledge the P38 came with a bottle jack,
8th Aug 2015 4:27pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
The D2 came with a bottle jack. Still got mine in the D2. John
8th Aug 2015 8:29pm |
The scissor jack will be cheaper, all adds up on the number of cars they build. And i suspect it was BMW sourced. |
8th Aug 2015 9:34pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8508 |
the original classics came with a jack which looked like a bottle but if i recall you had to wind it up with a long handle rather than pumping it. There is nothing that can't be fixed with a hammer😜😜
9th Aug 2015 2:58pm |
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 |
Many in the D3 world have had the jack fail and the general response from LR is along the lines of "We'll give you a new one if it fails, sir "... Visiting from DISCO3.CO.UK Discovery 3 TDV6 Auto HSE Zambezi Silver |
9th Aug 2015 3:02pm |
Yes now you mention it, it was a mechanical bottle jack with a screw thead. VW LT's had them instead of the hydraulic one their close relative the sprinter has. I suppose they're safer than a hydraulic bottle jack as there is no chance of the seals going but more fiddly to use. |
9th Aug 2015 4:23pm |
