Home > Wheels & Tyres > LandRover jacks are dangerous and completely useless !! |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
i think there are at least two sizes of Sprinter jack. I have one i acquired from a works van (which didn't have a spare anyway) about 14 years ago and that's a 2.7 ton jack, i've just bought another one for the boot of my Range Rover, which is slightly fatter and 3.5 tons. I expect the 4.6 ton sprinters come with the 3.5 ton jack. Both are more than adequate for lifting the Range Rover. as you're never going to be lifting the entire car off the ground, only 1 or two wheels, so a 1.5 ton jack is the minimum you need.
13th Aug 2015 4:57pm |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 118 |
This happened to me yesterday. I got a puncture 200 miles
22nd Aug 2015 6:59am |
What is interesting that a piece of equipment, that dangerous, is not subject to a safety recall. Maybe someone first needs to get trapped underneath a car or loose a foot or something to warrant some proper attention ???? Ridiculous and unacceptable. MY 2010 5.0 SC Galway green and sand interior!!
22nd Aug 2015 7:47am |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 |
I've got one of blue sprinter jacks and I used it twice a year to swap all my wheels over (winter/ summer). I also have deployable steps and I manage it without taking the steps off but still using the correct jacking points. |
That's interesting Buz1500. Do you have to
22nd Aug 2015 8:47am |
i would imagine if you have the car on level ground you could use the service jacking points on the front and rear subframes. The sprinter jack should fit between the exhaust at the rear. |
22nd Aug 2015 10:13am |
I make sure the steps are deployed by leaving a door open then I use just one piece of the extendable handle and operate it by reaching under the car. It takes a bit of effort but it's preferable to taking the steps off. I also put a block of wood under the jack before I start just to take up the gap between the jack and the jacking point. This means I get the car lifted sufficiently without needing to use the secondary piston on the jack. |
22nd Aug 2015 11:21am |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
It seems to me that modern cars just do not seem to have many places to jack from and the RR is as bad as it gets.You would think a motor so heavy would have somewhere better to jack.I had a wheel changed at a local tyreshop and the guy there almost had it on the floor as it slipped on the trolley jack,mind you I would not have put the jack where he did even though he did it for a living but to get it somewhere safe is quite awkward.!! |
22nd Aug 2015 10:35pm |
I suppose with old cars with a separate chassis pretty much all of which was strong enough to place a jack, or large axle castings thats true there are loads of places to put a jack.
22nd Aug 2015 10:46pm |
I have ordered a blue sprinter jack off eBay
24th Aug 2015 3:27pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3779 |
I've got one of the sprinter jacks of eBay I've modded the top (see elsewhere) and it works a treat, however it's taken to not closing fully when I've finished with it. Even if I push it closed, when I take the pressure off it expands a bit. Anyone else had this? is there a fix? should I be more worried than I am? which is not at all. Geoff |
24th Aug 2015 4:05pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 608 |
Just a semi-educated shot in the dark but if it's bouncing back then unless there's a mechanical cause it could be air in the hydraulic system. Some bottle jacks do have a bleed valve so could look into that? Ed |
24th Aug 2015 10:42pm |
I hope those of you with the sprinter jacks are still using something else under the car when jacked up to support it as there are a few cases of the seals in them going and the jack slowly letting the vehicle down.....
26th Aug 2015 8:17am |
the seals can go in any hydraulic jack. You can say they go on a small number of any type, including trolley jacks,
26th Aug 2015 9:39am |
