Home > Wheels & Tyres > LandRover jacks are dangerous and completely useless !! |
True, but the sprinter jacks are only designed for one or two tyre swaps in their life, they aren't really designed for much more....
26th Aug 2015 10:05am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35281 |
when i managed a tyre depot we used sprinter jacks regularly [on council grass cutters] so they can be used more than a few times.. ... - .- -.
26th Aug 2015 10:47am |
Sprinter jacks are rated higher than FFRR ones anyway Stan. IIRC they are a standard item which is designed to lift the corner or the largest Sprinter when fully laden. that's a lot more than a Rangie weighs.
26th Aug 2015 10:57am |
Yes seals can fail but so can scissor jacks
26th Aug 2015 1:59pm |
Rather different failure rates though KP. |
26th Aug 2015 2:30pm |
Maybe due to not so many on there using them as the scissor jack and their age being younger than the std jack? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
26th Aug 2015 2:33pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Exactly! ANY JACK can fail.
26th Aug 2015 2:37pm |
My personal choice more than anything and yes it could fail but its LESS likely to fail as its nowhere near as stressed lifting vehicles as the sprinter or trolley jack is
26th Aug 2015 2:47pm |
Of course it's your personal choice. I just don't see a problem with the 3 tonne sprinter jacks, lifting at worst 1.5 tonnes of Range Rover (you're never going to lift the entire car off the ground).
26th Aug 2015 3:22pm |
Everyone has their own choice
26th Aug 2015 3:35pm |
one of the advantages of the sprinter jack is they also have a high lift, but no they probably wouldn't be any more useful than your own in those situations.
26th Aug 2015 4:16pm |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 118 |
I got my sprinter 2.6t jack today off EBay, it's
27th Aug 2015 6:26pm |
MY 2010 5.0 SC Galway green and sand interior!!
28th Aug 2015 4:18am |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Well you live and learn. Managed to kerb one of my brand new alloys on Tuesday so I devised a plan to replace it with the spare and then have it repaired. Having seen the warnings re the LR supplied jack on here I was a little wary but I thought if I was careful to follow the safety rules how hard can it be to do a quick change of one wheel. First problem is getting the spare wheel and tool kit out of the underfloor storage area, I hadn't realised how heavy one of these 22" wheels is even using the sling device supplied by LR it is quite a task to get it out but managed in the end. Tool kit and chocks are stored next to the compressor and are easily accessible, not so the jack, this is stored as far away from human hands as is physically possible, you have to climb onto the lower half of the tailgate with legs waving in the wind to reach it and remove it, replacing it behind the rubber straps which hold it is a whole new experience which really requires three hands. Disable the side steps, jack in place and nuts freed off ready for a quick change and away we go. Not so I'm afraid, operating the jack beyond taking up the initial strain is virtually impossible, iam not as young or as strong as I used to be but still consider myself capable of a task such as this fairly easily but the jack is not, as the OP suggests fit for purpose in a safe manner. This was all carried out on a clean flat driveway on a fine day so how JLR expect anyone to use this piece of junk at the side of the road on a wet cold winter night is beyond me. All packed away afterwards and off out and bought a 3ton trolley jack for safety's sake and peace of mind. Agueroooooooooo. 93-20
13th Nov 2015 10:56am |
