Home > In Car Electronics (L322) > Cigar Lighters |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
Any specific relay that you swopped over, Cheet? John
20th Jun 2015 9:43am |
Cheet22 Member Since: 28 May 2015 Location: Hamilton Posts: 27 |
Just one of the greens - they all appear same |
20th Jun 2015 9:48am |
Ta John
20th Jun 2015 9:52am |
£5 for a 12v 40a relay from maplin and works a treat!
20th Jun 2015 12:44pm |
pietertje Member Since: 30 Nov 2014 Location: Rotterdam Posts: 152 |
Good job Cheet22... I will have a closer look today at my box to see what's going on.
21st Jun 2015 8:44am |
The problem is if there is indeed a bridge somewhere then putting a relay in will not overcome it. It will still be bridged and you won't be any further on finding out what is in place. John
21st Jun 2015 8:52am |
True that... Only one way to find out 2002 L322 V8 |
21st Jun 2015 9:00am |
Just found this in the workshop manual.
21st Jun 2015 10:31am |
Any technician/electrician here that can help me point out what to check first? I'm not to good in understanding the electrical diagram.
23rd Jun 2015 9:39am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
As I understand it the Socket in the rear luggage space is not a Cigar socket but an Auxiliary socket so it's operation will not be affected by the relay position on the rear fuseboard.
23rd Jun 2015 10:32am |
Thank you for your reply.
23rd Jun 2015 10:50am |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
You can buy inline voltage sensitive relays. You plug them in between the fridge and the accessory socket and it will switch the fridge off when the car battery drops below a certain level. |
23rd Jun 2015 11:25am |
I've had a look at the wiring diagrams and it appears the cigar sockets can be wired ignition controlled or not.
23rd Jun 2015 11:35am |
@ zirconblue: I know... But I don't like them to much... I will be installing headrest screens in the near future and I want to connect them to the aux socket wiring (cubby box). In fact i'm not planning on using the sockets at all but only the wiring to them.. I don't like it to much when connectors stick out of the sockets. So I'm looking at a more permanent fix.
23rd Jun 2015 11:51am |
