![]() | Home > Maintenance & Mods (L322) > new battery ...95ah or 110ah |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35641 ![]() ![]() |
well i've just replaced my old landrover/varta battery with a nice new 020 bosch from europarts, cost £117.44..
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2051 ![]() ![]() |
Scarey
its a type 020 bosch nigel with 110 amphrs and a 920 crank ...europarts is the cheapest and best place to get one... ... - .- -.
Cheers Stan
now's the time when batteries start failing so it make sense to get a new one if you've had non-starts..good idea re putting the new one on the newer car .. |
agreed stocky, the td6 is a big lump and there are loads of electrics on it..i'm glad i got mine when i did .. ... - .- -.
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I'm going to have to change mine, it lasted a whole 2 days of being parked up before it went flat. 2006 Mercedes CLS
what a new one |
I'm reading lots about flat batteries on RRs and the owners are replacing the battery but still having flat battery problems. It might be worth having the electrics checked out for excessive drainage before replacing the battery. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3785 ![]() ![]() |
Stocky, don't forget to put your bonnet in access mode otherwise its an absolute pain to change the battery with loads of skinned knuckels, bad back and pain... |
''service mode''.. |
davemfox Member Since: 31 Jul 2010 Location: Chester Posts: 43 ![]() ![]() |
Would this fit a FFRR Td6 - http://www.tayna.co.uk/610-200-Varta-Silve...P3200.html
yes definitely, the Short Code is I1 |
just a point dave, if you get the battery mail order and it goes pants then you might have a problem getting it back to them, buy it from europarts [if theres one near you] and you can take it back ... ... - .- -.
