![]() | Home > Technical (L322) > Think suspension pump is overworking? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8373 ![]() ![]() ![]() |
Sounds like a leak somewhere, out with the water and washing up liquid in a spray bottle and check for leaks, the bags are the first thing to check, raise to off road height to reveal more bag first...
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
+1 I thought I had a faulty suspension compressor actually it was a slow leak on an air bag. Which my halfords jack helpfully found for me by dropping the car hard enough to turn a slow leak into a dirty big hiss!
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Cannot find a leak. The car always stay up so surely a leak would result in that corner going down?
Get the codes read then, there could be some faults stored without it putting a light on..
Some times leaks get closed by the bag folding down as the air escapes , then when you start up again the bag inflates and starts to leak ![]() Rimini Red / Jet four zone climate remote park heater and no ugly kid windows. magnus satis quod turpis satis |
After 450 milesno fault
Tried to reset air suspension inactive with a cheap obd tool it would not clear or reset on steering recal and found no codes.
Think the noise is the new fuel pump fitted 2 week ago |
