Home > Maintenance & Mods (L322) > ZF 5HP24 Transmission rebuild - How To ? It begins.....
Page 5 of 14 <123 456 ... 121314>
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Well done pete.
Still watching in awe , and with help off rr phil you can't go wrong.
keep going mate. Thumbs Up
Post #322113 10th Apr 2015 7:00pm
Well got the new box fitted today, all went well, and what a difference.... silky smooth changes, pickup from rest is much, much better, the old torque convertor must have been well worn...
It really does feel like a new car, the silly grin is back on my face...!!!!
Thanks for everyone's thoughts and help, especially RRPhil, sorry this thread didn't turn out to be a rebuild but a swap.... Pete
Post #322635 14th Apr 2015 7:44pm
Weegie
Rebuild or replacement it was very interesting. You have my admiration. Well done. Thumbs Up John
GAP iiD BT
Post #322654 15th Apr 2015 3:32am
Welshdragon
Wales 2003 Range Rover Vogue 4.4 V8 Monte Carlo Blue
Well done Pete, a very intresting read Thumbs Up
May I ask what atf you put back in it? esso/mobil lt71141 ? If it dont work.......burn it!
If the IId tool cant fix it.......burn the FF.
If the FF cant be fixed......buy a Land Cruiser!
If the LC cant be fixed..............................................BUY a horse !!
Post #322680 15th Apr 2015 9:02am
Cheers
Yes it was the correct stuff this time, the old box had red oil in it when I bought it....
I bought 20ltrs of the stuff a few months ago to flush the old oil out and luckily had 9ltrs left, the new box took just over 8 to fill, the torque convertor is virtually impossible to drain fully so still had some in it...
Going to check the level again next week just to make sure....
Did 200 miles today, over to Manchester Airport and back and drove superb... Very Happy Very Happy Pete
Post #322746 15th Apr 2015 6:46pm
RRPhil
Pete,
That's great news that your £500 investment has turned out so well Thumbs Up
Phil
Post #322753 15th Apr 2015 7:38pm
gregdav
Well done pete glad it worked out for you and car is back to normal. Thumbs Up
greg.
Post #322756 15th Apr 2015 7:58pm
Yep, well pleased, Cheers
Phil... PM or email me re the old box... I'll try to get it packed up this week... Pete
Post #322758 15th Apr 2015 8:00pm
ebajema
Well done Pete, I'm glad you are mobile again Smile MY 2010 5.0 SC Galway green and sand interior!!
Post #322806 16th Apr 2015 5:56am
johnboyairey
Hi to all, I am removing my gearbox, same model as 'haylands' ( Bmw v8 )and wonder if anyone has removed a gearbox, and has any tips on getting the four flex plate to torque converter bolts out, as the front subframe is right in the way. I know how to remove them, just what tool has anyone had success with, ie an odd shaped ring spanner, or various sockets etc. I have to be careful not the round them off, and they are definitely not playing cricket today.
Post #328961 21st May 2015 9:16pm
John, PM replied to..., I don't think you will round them off they are high tensile bolts, I used a 17mm 3/8 drive deep socket, they are a pain though.... Pete
Post #328962 21st May 2015 9:19pm
andrew.aa
Italy 2004 Range Rover Westminster 4.4 V8 Java Black
hi , I started to remove my zf 5hp24 transmission, but I have a question about torque converter bolts.
I can remove grommet from bell housing, but I'm not able to access wiyh tools, due the black bar, and oil pan., so how remove 4 bolts inside hole Bow down
Post #334945 28th Jun 2015 10:27pm
andrew.aa
https://drive.google.com/file/d/0BwuJIrNHq...sp=sharing
Post #334946 28th Jun 2015 10:29pm
Pretty sure they are 17mm, you need a deep 3/8 drive socket on about a 1ft ratchet, feed it in and work your hands round the sides and it is possible... they are high tensile bolts so you won't round them off, they are very tight though...
You will also need more room than you have with it on axle stands to remove the box it is very big and very heavy..
Good luck Pete
Post #334948 28th Jun 2015 10:44pm
andrew.aa
thanks so much Thumbs Up sure I need more room, but I think is very hard remove bolts.
I already have all necessary tools, but no way to work, due the down rod an oil pan
And much hard to refit without working space.
I'm thinking remove engine and gearbox together, from front and do the work for chain, tensioner and valve cover, and transmission on one time.
anyway I will update you
Post #334958 28th Jun 2015 11:48pm
