Home > Wheels & Tyres > tyre size options on 22's |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7926 |
Anything taller is going to affect your speedo reading
10th May 2015 8:12am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
I run Conti 275/40/22 L405 tyres on my 2012 322 and they are a vast improvement over 285/35/22’s sir both in comfort and appearance... Your size IMHO look too skinny! 405 size fills the arches better.. Pic bellow
10th May 2015 9:26am |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
IMHO 285/35 R22 are just too thin and sports-car-esk!! Also, IIRC the Pirelli ones in this size are 109 load rated which makes the car push on a bit through the twistys. I'm running Hankook RH06 iin 305/40 R22 114V and in terms of appearance, grip (wet & dry) & noise I cannot fault them. They are also M+S rated See pic below.
10th May 2015 3:20pm |
I welcome bit of additional rim protection with 305's too I would imagine.
10th May 2015 3:23pm |
Any issues with rubbing? Even over BIG bumps with a loaded car? |
10th May 2015 4:08pm |
Craig - I'd be lying if I said no
10th May 2015 5:04pm |
Thats what i was lead to beleave sir
10th May 2015 10:27pm |
rr driver Member Since: 09 Dec 2013 Location: london Posts: 181 |
I have 22 OF Tigers on mine with 285/35 x 22 ( was on when i got the car) as i haven't been able to get a reasonably priced set of 20" Style 11 wheels, i am planning to just upgrade the tyres in the nest few months. I will probably follow what Craig has 275/40/22 - i am thinking of either the Conti or Vred All weather. any suggestions, also am i correct in thinking that there are no other alterations to be made- just get they tyres on and balanced etc.
10th May 2015 10:50pm |
cripboy Member Since: 10 May 2015 Location: Edinburgh Posts: 12 |
Hi
11th May 2015 12:32pm |
Nobody on here has tried yet as far as I’m aware so, you could be the Guineapig sir |
11th May 2015 12:38pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
285/40/22 are perfect. I'm running them. Would not consider anything less. |
11th May 2015 1:41pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 863 |
I have 4 x brand new 275 40 22 108Y Continental Cross Contact LX Sport (I believe the same as Craig mentions) tyres I bought recently but my plans have changed now, so if anyones interested, drop me a message. |
11th May 2015 4:58pm |
Just checked that size and they are unknown this side of the pond |
11th May 2015 5:32pm |
^^ There were like 3 options here. Went with the Toyo Proxy STII's |
11th May 2015 6:33pm |
