Home > In Car Electronics (L322) > tv in my 2003
bag 933s
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
tv in my 2003
this seems to be the only thing that doesnt work, it cant tune but has the stations there, is it something to do with digital now rather than a fault? if so, what can i do to make this operational please?
Post #323449 21st Apr 2015 1:09pm
you probably have an analogue tuner...you need a digital one to get tv nowadays and tbh i wouldnt bother.. ... - .- -.
Post #323451 21st Apr 2015 1:14pm
mjdronfield
Your best option is to fit a hybrid unit from a later BMW. I got one from a 2005 x5. Straight swap.
Or do this
http://www.carphonics.co.uk/digitaltv.htm
Which is the innards changed on the analogue unit.
Failing those two, personally, I wouldn't bother.
The above 2 options utilise all the factory fit buttons etc.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #323492 21st Apr 2015 4:28pm
bag 933s
do you mean purchase a BMW x5 head unit?
Post #323496 21st Apr 2015 5:04pm
mjdronfield
No, the TV tuner in the left hand side of the boot compartment........on the rr. It's under the boot floor on an x5.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #323498 21st Apr 2015 5:24pm
Zirconblue
Do the early touch screen sat nav's have Digital TV?
If not can they be upgraded with a TV module from a later touchscreen car?
Post #323700 22nd Apr 2015 4:25pm
Weegie
Mine doesn't. You can upgrade with a hybrid/digital tuner. Sorry I don't know when they changed to digital as standard.
As Stan say, not really worth the cost. John
GAP iiD BT
Post #323702 22nd Apr 2015 4:40pm
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Early tochscreen can be done, 5 minute job if you can find the correct tuner. You would need to make sure that you get the correct Jag/LR one as some don't work. From memory two wires unplugged from existing unit then plugged into new unit, new unit sits next too the old one to save stripping out loads of brackets etc... and also easy to remove if selling later. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #323705 22nd Apr 2015 4:42pm
Zirconblue
Will have to study the parts catalogues a bit then i think.
Whether it's worth it though, just depends on how cheaply you find the digital tuner.
Post #323726 22nd Apr 2015 5:58pm
rej
Mine was around the £300 mark just over a year ago. There is a difference between knowing your sh!t and knowing you're sh!t
Post #323733 22nd Apr 2015 6:25pm
Shocked you can buy a 50'' led tv in asda for that and have change for a few beers.... ... - .- -.
Post #323770 22nd Apr 2015 8:27pm
^ You won't be able to see out of the windscreen though. Smile
Post #323774 22nd Apr 2015 8:33pm
rej
But a 50" TV won't fit on the dash and streaming on the iPad uses too much data to be cost effective.
Not an essential but it was there, I saw the module and can always get something back if I sell when the FF goes. There is a difference between knowing your sh!t and knowing you're sh!t
Post #323775 22nd Apr 2015 8:34pm
mine has TV in it an to be honest for the most part it doesn't work, it does have a digital tuner but the signal for the most part isn't strong enough round here.
If you have after market tints it can affect the reception too....
What with all the online catchup services etc if I want to watch telly in the car i will do it on my phone as I have a 20Gb package with EE. (when parked of course Whistle ) There is nothing that can't be fixed with a hammer😜😜
Post #323776 22nd Apr 2015 8:34pm
...and if you do watch tv in your FF for any length of time, the battery will go flat.. ... - .- -.
Post #323779 22nd Apr 2015 8:46pm
