Home > In Car Electronics (L322) > tv in my 2003 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35293 |
you probably have an analogue tuner...you need a digital one to get tv nowadays and tbh i wouldnt bother.. ... - .- -.
21st Apr 2015 1:14pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7799 |
Your best option is to fit a hybrid unit from a later BMW. I got one from a 2005 x5. Straight swap.
21st Apr 2015 4:28pm |
bag 933s Member Since: 21 Apr 2015 Location: south west Posts: 13 |
do you mean purchase a BMW x5 head unit? |
21st Apr 2015 5:04pm |
No, the TV tuner in the left hand side of the boot compartment........on the rr. It's under the boot floor on an x5.
21st Apr 2015 5:24pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
Do the early touch screen sat nav's have Digital TV?
22nd Apr 2015 4:25pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3234 |
Mine doesn't. You can upgrade with a hybrid/digital tuner. Sorry I don't know when they changed to digital as standard.
22nd Apr 2015 4:40pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Early tochscreen can be done, 5 minute job if you can find the correct tuner. You would need to make sure that you get the correct Jag/LR one as some don't work. From memory two wires unplugged from existing unit then plugged into new unit, new unit sits next too the old one to save stripping out loads of brackets etc... and also easy to remove if selling later. There is a difference between knowing your sh!t and knowing you're sh!t
22nd Apr 2015 4:42pm |
Will have to study the parts catalogues a bit then i think.
22nd Apr 2015 5:58pm |
Mine was around the £300 mark just over a year ago. There is a difference between knowing your sh!t and knowing you're sh!t
22nd Apr 2015 6:25pm |
you can buy a 50'' led tv in asda for that and have change for a few beers.... ... - .- -.
22nd Apr 2015 8:27pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
^ You won't be able to see out of the windscreen though. |
22nd Apr 2015 8:33pm |
But a 50" TV won't fit on the dash and streaming on the iPad uses too much data to be cost effective.
22nd Apr 2015 8:34pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8516 |
mine has TV in it an to be honest for the most part it doesn't work, it does have a digital tuner but the signal for the most part isn't strong enough round here.
...and if you do watch tv in your FF for any length of time, the battery will go flat.. ... - .- -.
22nd Apr 2015 8:46pm |
