Home > In Car Electronics (L322) > tv in my 2003
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Always keep the engine running so the Ac can keep me at a comfy temp. Parked up for 3 hours in the O2 car park a couple of weeks ago while the kids went to X a Factor.
Surprised reception is as good as it is and when out of town can listen to the TV (no picture). I use the phone iZpad for Sky Sports etc... But goes through my 12gb data pretty quick and buffering is a pain when away from 4g. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #323783 22nd Apr 2015 8:53pm
mjdronfield
I watch the TV in mine most lunch times at work...... Top the battery up every few weeks with the ctek as I only do about 10 mile a day in the rr....... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #323785 22nd Apr 2015 8:56pm
Zirconblue
I take it this
http://www.ebay.co.uk/itm/RANGE-ROVER-LAND...4638ee3309
is the the module i'd need for my early touchscreen car. It looks basically the same as the original, whereas the modules from the 2009 onwards cars with HDD navigation don't fit the earlier cars.
Post #325866 3rd May 2015 8:37pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
This is for later touch screen cars only that use MOST fibre optics. The non touch screen version doesn't use MOST it uses ibus. You need an ex BMW digital tuner for a early Range Rover
Matt
Post #326888 9th May 2015 12:40pm
Zirconblue
That's ok, i have a touch screen with MOST.
Post #326908 9th May 2015 2:48pm
Zirconblue
Just fitted it, and i can confirm it works a treat with my 2004 Touch screen model.
Post #328189 16th May 2015 3:24pm
Simonbaz
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
Hi zirconblue
I also have a 2004 touch screen model with analogue tv and looking to upgrade to digital TV.Could you tell me the part number of the digital tuner you used to get yours working.looking on eBay there seems to be a few for sale but not to sure which one would be best.Do you know if there is more than 1 type of tuner I could use.
Many Thanks
Post #356939 14th Nov 2015 7:28pm
Zirconblue
http://www.ebay.co.uk/itm/RANGE-ROVER-LAND...1602845449
That one.
Post #356940 14th Nov 2015 7:31pm
