Home > Maintenance & Mods (L322) > Air Conditioning not cold |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Sounds like it is due a re-gas or at least a health check Land Rover Addict
9th Apr 2015 3:08pm |
I agree, it could be the liquid phase is almost gone, so enough pressure to keep the system working but not enough liquid to cool. Had it on my 4.2 SC as well, just a bit of R134a in it and cool air in 10 minutes MY 2010 5.0 SC Galway green and sand interior!!
9th Apr 2015 3:29pm |
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 |
So can this be done yourself with ease? If so, which product or would Halfords do something like this? |
9th Apr 2015 3:37pm |
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 |
Sounds as though you have a leak on the system somewhere. Current regulations require that a loss of refrigerant is traced then rectified and the system vacuum tested before being refilled with new refrigerant . Beware that some of these so called experts will just top up for a few bob and send you on your way, this is false economy as modern gases are in fact blended from different gases and have varying molecular size and therefore the smallest molecular gas will leak first rendering the remaining gases useless. Just topping up will result in a return to the garage in short time and is also illegal. Agueroooooooooo. 93-20
9th Apr 2015 3:41pm |
ok thanks.
9th Apr 2015 3:52pm |
I am wondering now whether to just do it myself;
9th Apr 2015 4:04pm |
I take it you did not understand my reply above. Agueroooooooooo. 93-20
9th Apr 2015 4:23pm |
Well I thought I did ... was planning on checking the pressure myself and topping up. If this was illegal, I suspect Halfords wouldn't be allowed to sell these bits to diagnose. |
9th Apr 2015 4:30pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3973 |
I strongly recommend you don't try and refill the ac system by yourself using one of the above kits.
9th Apr 2015 4:46pm |
It is not just like blowing a tyre up, a certain volume of gas as a liquid has to be put in the system. The way to do it properly is to have an empty system and fill from a known weight of liquid. Also to top up as I said before results in an unequal and useless blend of gas. If it is leaking now it will leak again when you top it up your way and just make things worse. Agueroooooooooo. 93-20
9th Apr 2015 4:50pm |
I use professional air con people - i.e. that's their sole business and that's where our local LR dealership take your vehicle! They aren't hard to locate and they are VERY thorough. Halfords....sorry but I'd look harder. Land Rover Addict
9th Apr 2015 7:00pm |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 |
I agree with Dmrr,have a ring round and get it done professionally,my mate used the 'Diy kit' on his car and it didn't work so he ended up paying someone who knew what he was doing and it worked a treat.He even told him that most people who think their air con was working good will be surprised just how much cooler it will be with a professional service.!! |
9th Apr 2015 7:41pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
A good tell tail that you have lost enough gas to lose the liquid phase is at idle you will here the compressor click in and it will make a whirring sound ,fully gassed up it will be quiet , and as above go to a professional you know it makes sense . 2008 MY Supercharged
10th Apr 2015 1:31am |
I wonder how Halfords and the kit manufacturers get around this.........
10th Apr 2015 5:59am |
